[mapguide-users] Deleting Feature Data Problems
Bruce Dechant bruce.dechant at autodesk.com
Tue Sep 19 18:58:54 EDT 2006
I'm not sure if this is fixed yet as I was not involved in this defect.
I am currently developing with the latest FDO (R069) with MapGuide SP1
and if I get a chance I'll try your use case below.
Build 1.01.17812 still uses FDO R050. See below:
Tux Build 178.12 Summary
Start Time: Thu 07/13, 12:15 AM
  End Time: Thu 07/13, 02:58 AM
TuxStudio build passed
TuxServer Windows build passed
TuxServer Linux build passed
TuxServerCommunity Windows build passed
TuxMigrationTool build passed
TuxStudioInstall build passed
TuxServerInstall build passed
TuxServerCommunityInstall build passed
TuxMigrationToolInstall build passed
Current Components (installed automatically):
  FDO                         50
  CsApi                       11e
  DETE                        M046
  Apache    (Bundled Config)  2.0
  Php       (PhpAgent)        5.0.5
  Tomcat    (JavaAgent)       5.5.12
Required Web Server for WebTier (choose one):
  IIS                         5 or 6
Required Web Server plug-in for WebTier:
  .NET Framework (.NETAgent)  2.0
  _____
From: Adam Herbert [mailto:adam at aemsaustralia.com.au]
Sent: September 19, 2006 4:51 PM
Subject: RE: [mapguide-users] Deleting Feature Data Problems
OK, This might be a dumb question but does that mean it's supposed to be
fixed in 1.01.17812?
  _____
From: Bruce Dechant [mailto:bruce.dechant at autodesk.com]
Sent: Wednesday, 20 September 2006 8:25 AM
Adam,
This is a known bug with the FDO R050 that was released with the
MapGuide 1.0 release.
Bruce
  _____
Sent: September 18, 2006 11:36 PM
Subject: [mapguide-users] Deleting Feature Data Problems
I am not sure if this is a bug or my error but when I try to use:
Dim deleteFilter As String = "PRIMARYINDEX = " & objectId
actionCommands.Add(New MgDeleteFeatures("actions", deleteFilter))
' Execute the "delete" commands
featureService.UpdateFeatures(resourceIdentifier, actionCommands, False)
My MgServer service dies and I have to restart it. Also the feature is
not deleted from the feature source.
I am successfully using MgInsertFeatures against this feature source so
I don't think it is a permissions issue. Anyway any ideas would be
greatly appreciated.
Regards,
Adam Herbert
IT Manager
AEM Solutions Pty Ltd
PO Box 514, Toowoomba Q. 4350
Phone: 07 4613 0455
Cell: 0437 599 907
Website: www.aemsaustralia.com.au <http://www.aemsaustralia.com.au>
Important Disclaimer and Warning
AEMS does not represent or warrant that any attached files are free from
computer viruses or other defects. The attached files are provided, and
may only be used, on the basis that the user assumes all responsibility
for any loss, damage or consequences resulting directly or indirectly
from use of the attached files. The liability of AEMS in any event is
limited to either the re-supply of the attached files or the cost of
having the attached files re-supplied.
NOTE: The views expressed by the individual in this message do not
necessarily reflect those of the organisation.
AEMS is committed to protecting the privacy of individuals, and is bound
by the principles of the Commonwealth Privacy Act (1988).
The information contained in this message is confidential and may be
legally privileged. The message is intended solely for the addressee(s).
If you are not the intended recipient, you are hereby notified that any
use, dissemination, or reproduction is strictly prohibited and may be
unlawful. If you are not the intended recipient, please contact the
sender by return e-mail and destroy all copies of the original message.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060919/9e1f7a4e/attachment.html
More information about the Mapguide-users mailing list
