[mapguide-users] Web Studio and the wonderful world of Microsoft .NET
Paul Spencer
pspencer at dmsolutions.ca
Wed Sep 20 06:19:31 EDT 2006
Thanks Kori,
there is a configuration setting to change the 'technology'
associated with Web Studio which is currently set as 'php'. I don't
believe we came across a use-case for it anywhere, but now we have one!
Thanks ... I (or rather Zak ;)) will be filing a project tracker
issue for this and hopefully the fix will be in the next release
Cheers
Paul
On 20-Sep-06, at 1:31 AM, Kori Maleski wrote:
> Just a critical FYI for all those out there using the .NET web
> extensions:
> In order to enable the Preview Pane, you must do the following:
> - Open up C:\Program Files\MapGuideOpenSource
> \WebServerExtensions\www\webstudio\js\WSView.js in a text editor.
> - Do a search and replace on “mapviewerphp/ajaxviewer.php”
> with “mapviewernet/ajaxviewer.aspx”
> - Stop and restart the MapGuide Server service
> - Clear your browser cache (important)
> You will then be able to access Web Studio with full previewing
> capabilities.
> I did a search and didn’t find this mentioned anywhere so I thought
> I would post.
> It would be prudent to put a setting in the config.xml to specify
> the web extension of choice in any subsequent update.
> Cheers,
> Kori Maleski
> GIS Consultant
> 403.651.3714 (Mobile)
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
More information about the Mapguide-users
