[mapguide-users] Opaque Labels in the AJAX viewer vs. the DWF viewer.
Warren Medernach warren.medernach at imaginit.ca
Thu Sep 21 12:20:46 EDT 2006
Hi Traian,
Fyi, I installed the 1.0.1 OS version on a VM for testing, and the
result is the same.
Any other suggestions to work around?
Thanks
Warren
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Wednesday, September 20, 2006 7:31 PM
Subject: RE: [mapguide-users] Opaque Labels in the AJAX viewer vs. the
DWF viewer.
You are using 1.0.0. As I said, in that case you should upgrade to the
latest build or service pack since there have been some fixes to that
code since.  There is a 1.0.1 release which should contain the fix.
Traian
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060921/34e8f87d/attachment.html
More information about the Mapguide-users mailing list
