[mapguide-users] How to check if session is expired?
    François Van Der Biest
    francois.van-der-biest at onf.fr
    Thu Sep 28 10:42:13 EDT 2006
François Van Der Biest a écrit :
> Jackie Ng a écrit :
>> But now when I try to access my map with this newly generated session
>> id. I
>> get "Resource not found" errors. I thought that session resources
>> would be
>> automatically created with the new session as stated in the API docs.
Hi Jackie,
I found a solution to my problem, where the map resource did not exist
in session repository at startup.
It seems that the creation of the map resources in the session
repository is done by the viewer, but it takes some time before this is
achieved. Therefore, I had to slow a little bit things before my script
completely executes itself.
Maybe it's a bit dirty, but at least, it works : I just inserted a
"usleep(500000);" before opening the map resource
($map->Open($resourceService, $mapName);) and startup is OK now.
Hoping this will help,
F.
More information about the Mapguide-users
