[mapguide-users] failed: Permission denied (13)
Chris Gountanis cgountanis at mpower-tech.com
Mon Apr 2 11:00:58 EDT 2007
Find the php.ini file and uncomment the save_path var. Make it something
like "C:\Program
Files\Autodesk\MapGuideEnterprise2007\WebServerExtensions\Php\SAVE" then
make sure IUSER has write access to that folder.
Chris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jose Manuel C G
Sent: Monday, April 02, 2007 9:54 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] failed: Permission denied (13)
In a clean windows XP/IIS/MG 1.0.2 install, I get this error:
u1q2c3ng4qtff2k6tqpb0, O_RDWR) failed: Permission denied (13) in D:\Archivos
de
programa\MapGuideOpenSource\WebServerExtensions\www\mapadmin\sessionvars.php
on line 241 PHP Warning: session_write_close()
[function.session-write-close]: Failed to write session data (files). Please
verify that the current setting of session.save_path is correct () in
D:\Archivos de
on line 241 Status: 302 Content-type: text/html X-Powered-By: PHP/5.0.5
Set-Cookie: PHPSESSID=0o4iju1q2c3ng4qtff2k6tqpb0; path=/ Expires: Thu, 19
Nov 1981 08:52:00 GMT Cache-Control: no-store, no-cache, must-revalidate,
post-check=0, pre-check=0 Pragma: no-cache Location:
servermanagement.php?PHPSESSID=0o4iju1q2c3ng4qtff2k6tqpb0
View this message in context:
http://www.nabble.com/failed%3A-Permission-denied-%2813%29-tf3506239s16610.h
tml#a9792358
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
