[mapguide-users] patch for Mouse Wheel Zoom, set scale and image on loading map in Ajax.
Ivan Miličević ivan at ineo.hr
Mon Apr 2 17:13:08 EDT 2007
You're the man!
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of José Manuel
Cerrejón González
Sent: Friday, March 30, 2007 1:36 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] patch for Mouse Wheel Zoom, set scale and image on
I've try to post the code in the internal list, but I don't how to register.
Anyway here the code. I've applied the changes on the 1.0.2, but in the last
version works fine.
Somebody who know how to do it, please e-mail me.
This patch use javascript to zoom with the wheel mouse, like in AutoCAD.
Another patch is to input in the scale bar, a scale manually.
You can see an icon in the toolbar when the map is loading.
All these changes in action here
<http://wms.diphuelva.es/mapguide/phpviewersample/index.php> . Click on the
help icon to see more features.
E-mail me with any problem.
Thank you.
  _____
[toolbar.templ]
In css:
  _____
        div.cssRefresh
            position: absolute;
            right:10px;
            top:4px;
  _____
The body seems like this. Rotating_arrow.gif is the image. You can design it
or use the attached:
  _____
<body class="Toolbar" onload="InitDocument()" leftmargin=10 topmargin=0
rightmargin=0 bottommargin=0 marginwidth=0>
    <div id="divRefresh" name="divRefresh" class="cssRefresh"><img
alt="loading"
src="../phpviewersample/images/common/rotating_arrow.gif"></div>
    <span id="ToolbarContent"><td></td></span>
    <div class="TextMetricsDiv" id="TextMetricsDiv"><span
class="TextMetrics" id="Metrics"></span></div>
  </body>
  _____
[ajaxmappane.templ]
About line 1350:
  _____
  if(requestObj.responseXML)
        var resp = ParseEnvelope(requestObj.responseXML.documentElement);
        if(resp == null)
            RequestFailed("Invalid XML response");
        else
            var frmParent = parent.frames ["tbFrame"];
            var objDivRefresh =
frmParent.document.getElementById("divRefresh");
            if(objDivRefresh!=null){  objDivRefresh.style.display='block'; }
            panX1 = extX1 = resp.lowerLeft.X;
  _____
Line 1463 after the changes:
  _____
    if(safari)
        curimg = (curimg == "mapImage1"? "mapImage2": "mapImage1");
    var objDivRefresh = frmParent.document.getElementById("divRefresh");
    if(objDivRefresh!=null){    objDivRefresh.style.display='none'; }
    return false;
  _____
Jose Manuel Cerrejon Gonzalez
jose.cerrejon at mapas-sll.com | gis at mapas-sll.com
I+D
MAPAS SLL <http://mapas-sll.com>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070402/c380935d/attachment.html
