[mapguide-users] Draw Circle
Farah
farah at egovernments.org
Tue Apr 3 03:27:17 EDT 2007
Hi Kencana,
I remember u telling me that you have figured out how to draw a circle.
Could you please give me some tips on this? For example, in the
OnCircleDigitized(Circle) method, what all attributes do we need to get from
the circle and using what methods? I couldn't find any help on this...:-(
So far, all I have got is:
function OnCircleDigitized(Circle)
var radius = Circle.Radius;
Also, how do u create the circle on the server side using the method:
CreateCurvePolygon?
Thanks and regards
Farah
-----Original Message-----
From: kencana kesuma [mailto:bluesky_dyx at hotmail.com]
Sent: Monday, December 04, 2006 1:25 PM
To: farah at egovernments.org
Subject: RE: polygon color
Hi Farah,
I guess I have figure out how to draw the circle already.
instead of using CreatePolygon command,
I used CreateCurvePolygon to draw the circle.
I defined 2 arc lat long position and it works.
Anyway, thank you very much.
Without your references, I guess I am not able to do it.
once again thank you.
Regards,
Kencana
>From: "Farah" <farah at egovernments.org>
>To: "'kencana kesuma'" <bluesky_dyx at hotmail.com>
>Date: Mon, 4 Dec 2006 13:12:51 +0530
>Hi Kencana..
>I don't know about this..i havent tried it...
>I will pass on any info that I get on this..if I do..!! :-)
>farah
>Sent: Monday, December 04, 2006 11:51 AM
>Hi,
>I mean,
>can we draw circle other than drawing polygon?
>I was wondering is there any API for drawing circle on the map.
>Thank you.
>Regards,
>Kencana
> >Date: Mon, 4 Dec 2006 11:52:02 +0530
> >Hi...
> >Ur welcome!
> >Im sorry....i didn't get u..! Which circle?
> >Regards
> >Farah
> >Sent: Monday, December 04, 2006 11:45 AM
> >Hi Farah,
> >Thank you very much for the reply...
> >It helps.:):):)
> >Anyway,
> >We use CreatePolygon for drawing the polygon
> >any idea for the circle?
> >Sorry for keep distrubing you
> >Please don't mind...
> >Thank you very much
> >Regards,
> >Kencana
> > >CC: <users at mapguide.osgeo.org>
> > >Date: Mon, 4 Dec 2006 11:31:34 +0530
> > >Hi Kencana,
> > >In the studio, when you are giving a style to a particular scale range:
> > >for
> > >a layer, we have an option to set the transparency ( from 0 to 100: 0
> >means
> > >not transaprent and as you go towards 100, the transparency increases
>and
> > >the colour changes accordingly!). Now if you save this layer as xml,you
> > >will
> > >get the required styling info and colour.
> > >For example:
> > ><AreaSymbolization2D>
> > > <Fill>
> > > <FillPattern>Solid</FillPattern>
> > > <ForegroundColor>80800000</ForegroundColor>
> > > <BackgroundColor>FF000000</BackgroundColor>
> > > </Fill>
> > > <Stroke>
> > > <LineStyle>Solid</LineStyle>
> > > <Thickness>0.0</Thickness>
> > > <Color>FFC0C0C0</Color>
> > > <Unit>Centimeters</Unit>
> > > </Stroke>
> > ></AreaSymbolization2D>
> > >This colours: forground: 80800000 and background: FF000000 give a
> >slightly
> > >transparent red shade to the polygon.
> > >Regards
> > >Farah
> > >Sent: Monday, December 04, 2006 9:43 AM
> > >Subject: polygon color
> > >Hi Farah,
> > >Do you know how to make the polygon bg color transparent?
> > >so that only the polygon fill and the outline layer can be seen?
> > >Hope you can help me out
> > >Regards,
> > >Kencana
> > >_________________________________________________________________
> > >Express yourself instantly with MSN Messenger! Download today it's
>FREE!
> > >http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
> >Express yourself instantly with MSN Messenger! Download today it's FREE!
>Don't just search. Find. Check out the new MSN Search!
>http://search.msn.click-url.com/go/onm00200636ave/direct/01/
Disclaimer by Mail Administrator - Yukthi
