[mapguide-users] patch for Mouse Wheel Zoom, set scale and
image on loading map in Ajax.
Jose Manuel C G
gis at mapas-sll.com
Tue Apr 3 11:51:24 EDT 2007
Sorry. Here the rest of the code:
1) Mouse Wheel:
In Ajaxmappane.templ:
//Added by J M Cerrejon
function handle(delta,event) {
var isIE = document.all;
var x = isIE ? event.clientX - mapPosX : event.screenX - mapPosX;
var y = isIE ? event.clientY : event.screenY;
if (delta < 0)
ZoomOut(x, y); // You can put here your function
else
ZoomIn(x, y);
function wheel(event){
var delta = 0;
if (!event) event = window.event;
if (event.wheelDelta) {
delta = event.wheelDelta/120;
if (window.opera) delta = -delta;
} else if (event.detail) {
delta = -event.detail/3;
if (delta)
handle(delta,event);
if (window.addEventListener)
window.addEventListener('DOMMouseScroll', wheel, false);
window.onmousewheel = document.onmousewheel = wheel;
// End code
<script>
</head>
<body...
2) Input box to the scale (statusbar.templ):
var tempValue;
function CalcKeyCode(aChar) {
var character = aChar.substring(0,1);
var code = aChar.charCodeAt(0);
return code;
function keyboardcontroller(val) {
var strPass = val.value;
var strLength = strPass.length;
var lchar = val.value.charAt((strLength) - 1);
var cCode = CalcKeyCode(lchar);
if (cCode < 48 || cCode > 57 ) {
var myNumber = val.value.substring(0, (strLength) - 1);
val.value = myNumber;
return false;
function setZoomToScale(val) {
if (val.value == "") {
val.value = tempValue;
return;
}else{
top.ViewerFrame.mapFrame.ZoomToScale(parseInt(val.value));
val.value="1: " + val.value;
document.getElementById(4).focus();
// End code
</script>
</head>
<body ...
... <input class="StatusField" id="2" type="text" readonly >...
<input class="StatusField" id="3" name="3" type="text"
onKeyUp="keyboardcontroller(this);" onKeyDown="if(event.keyCode==13)
document.getElementById(4).focus();" onfocus="this.style.backgroundColor =
'lightyellow';tempValue = this.value; this.value='';"
onblur="this.style.backgroundColor = '#f0f0f0'; setZoomToScale(this);"
onclick="this.focus();">
<input class="StatusField" id="4" type="text" readonly >
View this message in context: http://www.nabble.com/patch-for-Mouse-Wheel-Zoom%2C-set-scale-and-image-on-loading-map-in-Ajax.-tf3491633s16610.html#a9816211
