[mapguide-users] Filtering features on map with SelectFeatures
function
FGoulet
gouletf at dfo-mpo.gc.ca
Tue Apr 3 13:10:24 EDT 2007
Thanks, I was looking at that solution too.
I did successfuly change the layer definition but I have not be able to save
it back to the map in the user session yet...
I will push in that direction...
Frederic
You'll probably want to modify the Filter element of the LayerDefinition
so that the layer displays only your desired objects. The code below does
that for one of our maps, but it isn't a very good example because it
updates the Library resource rather than the layer in the Session
repository.
$QueryFilter='Drawing+%3D+%26apos%3B74%26apos%3B+AND+Dept+%3D+%26apos%3B136%26apos%3B'
// Load the Query Match Layer Definition template into a PHP DOM object
and
// modify its Filter node so we're displaying the right building and
floor.
$doc = DOMDocument::load('QueryMatch.LayerDefinition.xml');
$FilterNode = $doc->getElementsByTagName('Filter')->item(0);
$FilterNode->nodeValue = $QueryFilter;
$LayerDefinition = $doc->saveXML();
$byteSource = new MgByteSource($LayerDefinition,
strlen($LayerDefinition));
$byteSource->SetMimeType(MgMimeType::Xml);
$tempResourceID = new
MgResourceIdentifier("Library://HumboldtFM/Layers/QueryMatch.LayerDefinition");
$resourceService->SetResource($tempResourceID, $byteSource->GetReader(),
null);
James Card
California CAD Solutions, Inc.
209 578-5580
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Filtering-features-on-map-with-SelectFeatures-function-tf3486952s16610.html#a9818609
