[mapguide-users] build_oem.sh issues
Chris Gountanis cgountanis at mpower-tech.com
Wed Apr 4 20:42:24 EDT 2007
I am waiting the new packages for Linux as promised. I am assuming this will
be with the new release of Mapguide with possible Java fixes??? Any ideas
when those will be available so we can all try the Linux side of things
again. It seemed to be a consensus that no one wants to run Fedora Core 4
since it is not supported and security updates will have to be manual. Same
with any out dated release be it CentOS or old school RedHat. I got things
running on the 2006.1 Gentoo and attached the manual to this list awhile
back but it was no piece of cake.
Chris
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Walt
Welton-Lair
Sent: Wednesday, April 04, 2007 4:16 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] build_oem.sh issues
Note: it's a good idea to include the full error stack so we can see what
the actual problem is.  The last line doesn't help much.
With ACE a common build problem involves the file Svc_Conf.l.cpp, and the
error message usually includes something involving "unterminated if".  Is
this the error you're getting?  You'll run into this problem if you run
aclocal / libtoolize / automake / autoconf / configure before running
build_oem.sh.  I suggest deleting your ACE directory and re-extract it, and
then try running build_oem.sh again.
Walt
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jonathan Bolich
Sent: Tuesday, April 03, 2007 8:50 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] build_oem.sh issues
I am trying to install mapguide but can't get past build_oem.sh
It fails with the ace 5.4 section. the final lines say:
make: *** [all] Error 2
ACE 5.4: Error build failed (0)....................
I tried to increase my swap space but that didn't change anything.
Any thoughts or things I could try I would be grateful
thanks
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070404/7216c222/attachment.html
