[mapguide-users] Losing Session ID
Jackie Ng
jackie.ng at aecsystems.com.au
Tue Apr 10 08:48:42 EDT 2007
Hi There,
I noticed that there are two <form> tags in that markup, one being
server-side and the other is not.
You could be losing your session id because it is written to the non
server-side form. If you write the session id to both <form> tags, then
GetParameters() should retain that session id.
Hope that helps.
- Jackie
Micha Lehmann wrote:
> Hi there,
> i´m going to develop a streetname/housenumber search
> i created a master detail drop down list in visual studio 2005 express
> edition, right now i´m able to choose a ID from these list, the lists
> are auto post back enabled, so the site is refreshing each time you
> change a name and/or a number...and then i always loose my session ID
> the same result if i´m starting a *.aspx from the task pane frame
> whats causes this?
> Thank you
> Michael
> <%@ Page Language="C#" Debug="true" %>
> <%@ Import Namespace = "OSGeo.MapGuide"%> <!--import der
> Klassenbibliotheken -->
> <!-- #Include File="utilityfunctions.aspx -->
> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
> "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
> <script runat="server">
> protected void DropDownList1_SelectedIndexChanged(object sender,
> EventArgs e)
> </script>
> <html xmlns="http://www.w3.org/1999/xhtml" >
> <head runat="server">
> <title>Unbenannte Seite</title>
> </head>
> <body>
> <form id="form1" runat="server">
> <div>
> <asp:DropDownList ID="DropDownList1" runat="server"
> DataSourceID="ObjectDataSource1"
> DataTextField="C01" DataValueField="C02"
> OnSelectedIndexChanged="DropDownList1_SelectedIndexChanged"
> AutoPostBack="True">
> </asp:DropDownList>
> <asp:DropDownList ID="DropDownList2" runat="server"
> AutoPostBack="True" DataSourceID="ObjectDataSource2"
> DataTextField="C12" DataValueField="C01">
> <asp:ListItem></asp:ListItem>
> </asp:DropDownList>
> <asp:ObjectDataSource ID="ObjectDataSource1" runat="server"
> InsertMethod="Insert"
> OldValuesParameterFormatString="original_{0}"
> SelectMethod="GetData"
> TypeName="DataSet1TableAdapters.ALBSTRASSENTableAdapter">
> <InsertParameters>
> <asp:Parameter Name="C01" Type="String" />
> <asp:Parameter Name="C02" Type="String" />
> </InsertParameters>
> </asp:ObjectDataSource>
> <asp:ObjectDataSource ID="ObjectDataSource2" runat="server"
> SelectMethod="GetDataByC13"
> TypeName="DataSet2TableAdapters.E1000TableAdapter">
> <SelectParameters>
> <asp:ControlParameter ControlID="DropDownList1" Name="C13"
> PropertyName="SelectedValue"
> Type="String" />
> </SelectParameters>
> </div>
> </form>
> // Display a form prompting the user to enter the beginning
> // portion of the parcel owners name. Submitting this form
> // replaces the content of this frame with a list of matching
> // results.
> // If a Search has already been run and the results are still
> // visible (e.g. if the ParcelMarker layer is visible), then
> // display an button allowing the user to clear the previous
> // search results as well.
> String mgSessionId = GetParameters()["SESSION"];
> try
> // Initialize the web-tier and connect to the Tux Site using
> // the Tux session identifier stored in PHP session state.
> InitializeWebTier();
> MgUserInformation userInfo = new MgUserInformation(mgSessionId);
> MgSiteConnection siteConnection = new MgSiteConnection();
> siteConnection.Open(userInfo);
> // Create a ResourceService object and use it to open the Map
> // object from the sessions repository. Use the Map object to
> // determine if the "ParcelMarker" layer is visible.
> MgResourceService resourceService =
> siteConnection.CreateService(MgServiceType.ResourceService) as
> MgResourceService;
> MgMap map = new MgMap();
> map.Open(resourceService, "Siel660355");
> //MgLayer layer = GetLayerByName(map, "ParcelMarker");
> //showClearButton = (layer == null) ? false : layer.GetVisible();
> catch (MgException mge)
> Response.Write(mge.GetMessage());
> Response.Write(mge.GetDetails());
> <form method="post" action="suche2.aspx">
> <p><input name="IDNR" type="text" value="<%=
> DropDownList2.SelectedValue%>" /></p>
> <p><input name="sessionID" type="text" value="<%= mgSessionId%>"
> /></p>
> <p><input type="submit" value="Suche" /></p>
> </form>
> Response.Write(mgSessionId);
> </body>
> </html>
View this message in context: http://www.nabble.com/Losing-Session-ID-tf3551971s16610.html#a9918998
