[mapguide-users] Losing Session ID
Micha Lehmann
paradoxe_vogelkunde at yahoo.de
Tue Apr 10 09:56:50 EDT 2007
When i´m going to put these line into i get a error:
Compiler Error CS0103
The name 'mgSessionId ' does not exist in the current context
the code is like this:
<%@ Page Language="C#" Debug="true" %>
<%@ Import Namespace = "OSGeo.MapGuide"%> <!--import der Klassenbibliotheken
<!-- #Include File="utilityfunctions.aspx -->
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<script runat="server">
protected void DropDownList1_SelectedIndexChanged(object sender,
EventArgs e)
</script>
<html xmlns="http://www.w3.org/1999/xhtml" >
<head runat="server">
<title>Unbenannte Seite</title>
</head>
<body>
<form id="form1" runat="server">
<div>
<input type="hidden" name="SESSION" id="SESSION"
value="<%=mgSessionId%>" />
<asp:DropDownList ID="DropDownList1" runat="server"
DataSourceID="ObjectDataSource1"
DataTextField="C01" DataValueField="C02"
OnSelectedIndexChanged="DropDownList1_SelectedIndexChanged"
AutoPostBack="True">
</asp:DropDownList>
<asp:DropDownList ID="DropDownList2" runat="server"
AutoPostBack="True" DataSourceID="ObjectDataSource2"
DataTextField="C12" DataValueField="C01">
<asp:ListItem></asp:ListItem>
</asp:DropDownList>
<asp:ObjectDataSource ID="ObjectDataSource1" runat="server"
InsertMethod="Insert"
OldValuesParameterFormatString="original_{0}"
SelectMethod="GetData"
TypeName="DataSet1TableAdapters.ALBSTRASSENTableAdapter">
<InsertParameters>
<asp:Parameter Name="C01" Type="String" />
<asp:Parameter Name="C02" Type="String" />
</InsertParameters>
</asp:ObjectDataSource>
<asp:ObjectDataSource ID="ObjectDataSource2" runat="server"
SelectMethod="GetDataByC13"
TypeName="DataSet2TableAdapters.E1000TableAdapter">
<SelectParameters>
<asp:ControlParameter ControlID="DropDownList1" Name="C13"
PropertyName="SelectedValue"
Type="String" />
</SelectParameters>
</div>
</form>
// MG Anmeldegedöns
String mgSessionId = GetParameters()["SESSION"];
try
// Initialize the web-tier and connect to the Tux Site using
// the Tux session identifier stored in PHP session state.
InitializeWebTier();
MgUserInformation userInfo = new MgUserInformation(mgSessionId);
MgSiteConnection siteConnection = new MgSiteConnection();
siteConnection.Open(userInfo);
// Create a ResourceService object and use it to open the Map
// object from the sessions repository. Use the Map object to
// determine if the "ParcelMarker" layer is visible.
MgResourceService resourceService =
siteConnection.CreateService(MgServiceType.ResourceService) as
MgResourceService;
MgMap map = new MgMap();
map.Open(resourceService, "Siel660355");
//MgLayer layer = GetLayerByName(map, "ParcelMarker");
//showClearButton = (layer == null) ? false : layer.GetVisible();
catch (MgException mge)
Response.Write(mge.GetMessage());
Response.Write(mge.GetDetails());
<form method="post" action="suche2.aspx">
<p><input name="IDNR" type="text" value="<%=
DropDownList2.SelectedValue%>" /></p>
<!-- <p><input name="sessionID" type="text" value="<%= mgSessionId%>"
id="Text1" /> </p> -->
<p><input type="submit" value="Suche" /></p>
</form>
</body>
</html>
Maybe i have to write the GetParameters Function in another way?
it´s like this
NameValueCollection GetParameters()
return Request.HttpMethod == "GET" ? Request.QueryString : Request.Form;
Michael
Try putting <input type="hidden" name="SESSION" id="SESSION"
value="<%=mgSessionId%>" /> in the server-side form. When your page posts
back, it should now be part of the Request.Form collection, which can be
retrieved by GetParameters()
- Jackie
View this message in context: http://www.nabble.com/Losing-Session-ID-tf3551971s16610.html#a9920249
