[fdo-users] RE: [mapguide-users] Advanced WMS providerconfiguration
Chris Tweedie chrislist at narx.net
Sun Apr 15 22:37:07 EDT 2007
Thanks for the pointers Jason. Looks like i'll have to revisit this one later unless someone else has a spark? I couldnt get past the schema errors either (and still thoroughly confused over the featureserver > layer interaction)
I'm also curious on RFC5 ... there is very little detail anywhere apart from the airy-fairy high level detail.
Chris
On Fri, 13 Apr 2007 13:54:16 -0700, "Jason Birch" <Jason.Birch at nanaimo.ca> wrote:
> Hi Chris,
> It looks like the config file editor in Studio either doesn't work
> properly for WMS, or I'm doing something wrong.  I've made it past this
> but run into another roadblock.  I'll outline my steps so far though.
> The MapAgent API test pages are required for this process.  The default
> location for these is:
> http://localhost:8008/mapguide/mapagent/index.html
> Here's a quickie overview:
> The WMS Data Connection is actually known as a FeatureSource in the
> MapGuide repository, and is stored as a Resource.  To find the
> ResourceID for your WMS data connection, log into the above URL and run
> the EnumerateResources call.  The most recently added resources are
> generally at the bottom of the list.  In my case, the ResourceID for my
> FeatureSource was "Library://NASA_WMS.FeatureSource"
> All resources have a ResourceHeader (which defines what type of content
> they contain - we don't have to care about this) and a ResourceContent
> (which contains information describing the resource, in this case the
> connection parameters).  These can be viewed by clicking on the
> appropriate links in the lower-left pane:  GetResourceHeader and
> GetResourceContent.  Fill in your ResourceID and click on Submit.
> For my WMS resource, the ResourceContent looks like:
> <?xml version="1.0" encoding="utf-8"?>
> <FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
>   <Provider>OSGeo.WMS</Provider>
>   <Parameter>
>     <Name>FeatureServer</Name>
>     <Value>http://wms.jpl.nasa.gov/wms.cgi</Value>
>   </Parameter>
> </FeatureSource>
> What you need to do to link your configuration document (stored as
> ResourceData) with this FeatureSource is to add a line to this resource
> content.  The easiest way to do this is to view the source of the above
> call, save it to the text file, and then edit it.  You need to add a
> ConfigurationDocument element to the ResourceContent, making it look
> something like this:
>   <Parameter>
>   </Parameter>
>   <ConfigurationDocument>config.xml</ConfigurationDocument>
> </FeatureSource>
> (assuming your configuration XML is called config.xml)
> When you have edited this file, use the SetResource call in the MapAgent
> API pages.  Fill in your ResourceID, browse for your new ResourceContent
> xml file in the Content area, leave the Header area blank, and click on
> Submit.
> As an aside, users that don't have Studio can upload the config file
> through this web interface using the SetResourceData call.
> This is where I hit a roadblock.  I've been using the NASA config file
> from the unit tests and the server is complaining because it can't
> validate the document (can't find FdoDocument.xsd).  I'm wondering if
> there is an easy workaround, like uploading the schema document to
> MapGuide, but don't have time right now to play with it.
> Jason
> -----Original Message-----
> From: Chris Tweedie
> Subject: [fdo-users] Advanced WMS provider configuration
> Hi Jason, thanks for the additional info.
> I'm still a little confused on the relationship between the config file
> attached to the data connection and the mapguide layer. I used the
> multi-layer XML example to define multiple layers, however how do i then
> create a new mapguide layer based on the custom commands? If i try to
> create a layer based off the connection, it simply queries the WMS
> featureserver again and gives me a list of the featuretypes as usual?
> <Layer name="srtm_mag">
>  <Style name="default"/>
> </Layer>
> <Layer name="global_mosaic">
>  <Style name="pseudo"/>
> </Layer>
> If i can finish this last step it certainly will solve my problems
> Chris
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
Chris Tweedie
