[mapguide-users] RE: An exception occurred in DB XML component.
Error: Out of memory in NsSAX2Reader parse
Steve Dang
steve.dang at autodesk.com
Tue Apr 17 12:24:26 EDT 2007
Please submit details as a bug report. The instruction can be found at:
http://trac.osgeo.org/mapguide/wiki/SubmitTicket
Thanks.
Steve.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of rropegod
Sent: Tuesday, April 17, 2007 6:47 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: An exception occurred in DB XML component.
Pentium IV 2.6 Ghz ,intel Core 2 Duo
Ram: 4Gb
DD: 160Gb 10000RPM
Windows 2003 Server
particion 60gb os, 100gb title
user: 50 (pick concurrent)
perfomance 50%
mge7_server_sp1.exe installed
thanks
Steve Dang wrote:
> Can you be more specific about your load/system (e.g. OS, RAM, # of
> users, data, etc.).
> Thanks,
> Steve.
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Monday, April 16, 2007 10:29 PM
> Subject: [mapguide-users] An exception occurred in DB XML component.
> mapguide version 1.0
> this with the installed patches but when the site this with its
greater
> load
> presents/displays the following error
> the web is masive user
> An exception occurred in DB XML component. Error: Out of memory in
> NsSAX2Reader parse File: ..\src\dbxml\nodeStore\NsSAX2Reader.cpp Line:
> 352An
> NsSAX2Reader
> parse File: ..\src\dbxml\nodeStore\NsSAX2Reader.cpp Line: 352
Exception
> occurred in method MgResourceDefinitionManager.ValidateDocument at
line
> 429
> in file
c:\build_tux_area\mgdev\server\src\services\resource\ResourceDefinitionM
> anager.cpp
> Type 'OSGeo.MapGuide.MgDbXmlException' in Assembly 'MapGuideDotNetApi,
> Version=1.0.0.17864, Culture=neutral, PublicKeyToken=null' is not
marked
> as
> serializable.
> please help
http://www.nabble.com/An-exception-occurred-in-DB-XML-component.-Error%3
> A-Out-of-memory-in-NsSAX2Reader-parse-tf3588769s16610.html#a10029075
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
A-Out-of-memory-in-NsSAX2Reader-parse-tf3588769s16610.html#a10034595
