[mapguide-users] Changing properties of 50 layers
Jose Manuel C G gis at mapas-sll.com
Thu Apr 19 05:28:15 EDT 2007
I made a ajax web based application to change this resources. So it's easy to
implement. The idea is set a .xml file with the changes, and upload the
resource with a loop, renaming the xml and uploading to their path.
For example, in a loop: ajaxUploadLayer.php?layer=layer1.xml&path=/Country1,
ajaxUploadLayer.php?layer=layer2.xml&path=/Country2,...
The rest, you can imagine...
View this message in context: http://www.nabble.com/Changing-properties-of-50-layers-tf3605876s16610.html#a10074635
