[mapguide-users] MAP3D 2008 and FDO 3.2.1
Traian Stanev
traian.stanev at autodesk.com
Fri Apr 20 13:00:11 EDT 2007
Depending on what you need to accomplish, it may be good enough to
compile against 3.2.2.
3.2.2 and 3.2.1 are binary compatible so your stuff will likely work in
Map if compiled with 3.2.2.
Traian
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
Sent: Friday, April 20, 2007 11:19 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] MAP3D 2008 and FDO 3.2.1
I'm trying to compile sont tools for AutoCAD map 3D 2008
And i can not find the proper fdo library.
Map3D 2008 is compiled with fdo version 3.2.1
on fdo.osgeo.org there are only version 3.2.0 and 3.2.2 beta
Anybody knows where i can find these files?
View this message in context:
http://www.nabble.com/MAP3D-2008-and-FDO-3.2.1-tf3618870s16610.html#a101
04426
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
