[mapguide-users] Map Studio Preview cannot connect to site
Dave Wilson dave.wilson at autodesk.com
Fri Apr 20 18:31:26 EDT 2007
What API language did you go with .NET?
There have been known cases, but yet to be reproduced and debugged where
the virtual directory structure is incomplete after the Web Extensions
install for .NET. This sounds something like that. Uninstalling and
reinstalling the Web Extensions should fix that. You might even try a
repair.
Although to be honest the portion of the install that is usually missing
is the ajaxviewer virtual directory.
You can test your mapagent via
http://localhost/mapguide/mapagent/index.html.
Select Feature and then below select GetProviders and submit that. You
should get a list of providers from your server.
Dave
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Robbins,
Nathan
Sent: Friday, April 20, 2007 3:02 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Map Studio Preview cannot connect to site
Hello,
I have just tried installing map guide and I am able to go into site
administrator.
However, I have installed mapguide studio preview and cannot connect to
my site.
I get an "unexpected error in contacting site URL" error message.
I also get the following message when trying to verify my mapagent
install:
Configuration file "c:\inetpub\wwwroot\../webconfig.ini" cannot be found
or cannot be opened.
Exception occured in method MgConfiguration.LoadConfiguration at line
110 in file .\System\Configuration.cpp.
I am running Windows Server 2003.
Any thoughts or suggestions?
Nathan Robbins
GIS Specialist
Direct 919-872-6652 Ext. 276
Main 919-872-6600 Fax 919-872-7996
nrobbins at ensr.aecom.com
ENSR
7041 Old Wake Forest Road
Raleigh, NC 27616
www.ensr.aecom.com <http://www.ensr.aecom.com/>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070420/5e74911f/attachment.html
