[mapguide-users] RE: Unable to start mgserver.exe service onwindows2003
Nimrod Cnaan nimcnaan at Hotmail.com
Mon Apr 23 10:00:40 EDT 2007
All is working, the problem solved. The solution laid upon IIS 6.0
configuration, under the “web services extensions”, I hade to allow all
unknown ISAPI & CGI extensions
Nimrod Cnaan wrote:
> Thank you for your detailed unsure, it helped to understand. But I seem to
> have the same problem, after I have asked from the internet hoster to open
> ports 2800-2802 for my mgos 1.1.0
> Mybe the reson is because it is being HOST on a VPS
> I’ll try asking the forum once again
> From:  "Jason Birch" <Jason.Birch at nanaimo.ca>
> Reply-To:  MapGuide Users Mail List
> <mapguide-users at lists.osgeo.org> To:  "MapGuide Users Mail
> List" <mapguide-users at lists.osgeo.org> Subject:  RE:
> [mapguide-users] Unable to start mgserver.exe service onwindows2003
> Date:  Sat, 21 Apr 2007 09:14:13 -0700 >You can use: >
> >netstat -abnp tcp > >to see what's using the port that you
> require.  The -b option can be _extremely_ slow; you might want
> to try without it first. > >The version I'm running (1.2.0-beta)
> appears to use ports 2810-12. > >The ports used by MapGuide are
> specified in the serverconfig.ini file, typically located at: >
> >C:\Program
> Files\MapGuideOpenSource\Server\Bin > >Jason >
> >________________________________ > >From:
> mapguide-users-bounces at lists.osgeo.org on behalf of Nimrod Cnaan >Sent:
> Sat 2007-04-21 3:44 AM >To: mapguide-users at lists.osgeo.org >Subject:
> [mapguide-users] Unable to start mgserver.exe service on windows2003 >
> > > > >Unable to start the mgserver.exe service on 'windows
> 2003 SiteServer', the >service starts and then stops, lunching an
> unknown Error massage. When I try >to run the mgserver from command
> line I get the massage: > >"Server starting . . . " >"Proj4
> coordinate system library" >"Port 2801 is not availibale pleas try
> using different port  . . " > >I'm using MGOS 1.1.0
> inviroment > >My Q
> are >1.      what protocol dose it need -
> TCP or UDP >2.      dose anyone know what
> this port are used for & would I need to open any >other ports.
> >3.      where can I find
> documentation  on those  subjects > >
> ><< winmail.dat >>
> >_______________________________________________ >mapguide-users
> mailing list >mapguide-users at lists.osgeo.org
> >http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Express yourself instantly with MSN Messenger! MSN Messenger  Download
> today it's FREE!
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Unable-to-start-mgserver-on-a-windows-2003-VPS-tf3622627s16610.html#a10140793
