[mapguide-users] RE: what is the use of mapagent?
Dhirendra Kumar dhirendra.mgos at gmail.com
Thu Apr 26 11:30:44 EDT 2007
Hi All,
Mapguide is the alias name in file httpd.conf line number 1971 Alias
/mapguide "C:/Program Files/MapGuideOpenSource/WebServerExtensions/www/" so
check it.
Regards;
Dhirendra kuma
JasonBirch wrote:
> Hello,
> The calls to MapAgent are not documented anywhere yet.  It's on my list of
> stuff I'd like to do, but... time is hard to come by :)
> For the most part, the MapAgent calls are very similar to the API
> functions.  You can reverse-engineer the parameters either by using the
> MapAgent test scripts (http://localhost:8008/mapguide/mapagent/index.html)
> or by reading through the source:
> http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Web/src/HttpHandler/
> It can be a bit tough going, partly because the parameter strings are
> stored in a resource file, so you have to keep referring to this to figure
> out what the actual parameters that you need to send are:
> http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp
> <http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp>
> Jason
> ________________________________
> From: xiexie
> Subject: [mapguide-users] what is the use of mapagent?
> I am studing mapguide.I hope somebody can give me some information about
> mapagent.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/what-is-the-use-of-mapagent--tf3649172s16610.html#a10202811
