Re:[mapguide-users] RE: Need an FDO connection...
Milan Lazecky el.migno at post.cz
Sun Apr 29 10:51:07 EDT 2007
Thank you very much Jackie, I understand it all - but it gives me an error - can you tell me what does it mean?
An exception occurred in DB XML component. Error: XML Indexer: Fatal Parse error in document at line, 1, char 72. Parser message: The prefix 'xsi' has not been mapped to any URI Exception occurred in method MgResourceDefinitionManager.ValidateDocument at line 429 in file c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
I tried to upload the resources what exist (GetResourceHeader/Content from existing Feature and then SetRes... back), but the error is still the same. Well, I really don't have any directory "build_bond_area...".
Thanks...
Milan
> ------------ Původní zpráva ------------
> Od: Jackie Ng <jackie.ng at aecsystems.com.au>
> Předmět: [mapguide-users] RE: Need an FDO connection...
> Datum: 27.4.2007 01:34:15
> Hi Milan,
> Try this:
> Go to the mapagent page http://<your mapguide site>/mapagent/index.html
> Click "Feature" under Services API
> Click "GetFeatureProviders" underneath.
> You will get an xml description of all available providers. Find the provide
> you're after and take note of what connection parameters are available under
> the <ConnectionProperties> section
> Create an xml file that looks like the following:
> <FeatureSource xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
>         <Provider>%provider name%</Provider>
> 	<Parameter>
>                <Name>%parameter name%</Name>
>                <Value>%parameter value%</Value>
>         </Parameter>
> </FeatureSource>
> Fill in the blanks, and upload it to your target feature source using
> "SetResource"
> Hope that helps.
> - Jackie
> Milan Lazecky wrote:
> > Thank you Simon,
> > it seems I can do it this way, I will try.
> > But anyway - can somebody tell me how to establish the provider connection
> > WITHOUT using the Autodesk MapGuide Studio? I  have used up the 60 days
> > trial ;-)
> > Thanks...
> > Milan
> >> Od: Simon Pelicon <simon at sl-king.com>
> >> Předmět: RE: [mapguide-users] Need an FDO connection...
> >> Datum: 25.4.2007 14:26:24
> >> Hi!
> >> You can visit our web site and take a look at
> >> http://www.sl-king.com/fdooracle/KingOracleXE/KingOracleXE.html flash
> >> movie (Use Oracle XE with MapGuide).
> >> There is an example with King Oracle provider, but the procedure is
> >> simmilar  for King.MsSqlSpatial provider.
> >> Simon Pelicon
> >> -----Original Message-----
> >> From: mapguide-users-bounces at lists.osgeo.org
> >> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Milan
> >> Lazecky
> >> Sent: Wednesday, April 25, 2007 1:25 PM
> >> To: mapguide-users at lists.osgeo.org
> >> Subject: [mapguide-users] Need an FDO connection...
> >> Hi.
> >> I am sorry for this beginner question, but I can't find out anything on
> >> my own...
> >> I want to add a new layer to my MGOS project - but not SDF nor SHP. I
> >> know about FDO connection but I don't know how to use it in MGOS :-(   I
> >> need to add raster files, connect a geodatabase (I will try MS SQL
> >> Server via sl-king connector) etc.
> >> Please, I need a short step-by-step tutorial on how to add a layer via
> >> FDO in WebStudio (or MapAgent?).
> >> Thank you very much...
> >> Milan
> >> PS: Well, I think there is a lot of people waiting for some tutorials...
> >> Don't you think about one?
> >> _______________________________________________
> >> mapguide-users mailing list
> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Need-an-FDO-connection...-tf3644777s16610.html#a10210995
> Sent from the MapGuide Users mailing list archive at Nabble.com.
