[mapguide-users] RE: RE: Setting up own security with MapGuide
Ismael Cams
mapguide2007 at gmail.com
Wed Aug 1 10:15:36 EDT 2007
Thanks for the proposed solution Martin.
Unfortunately I thought it would be a good idea to have the application
integrated as much as possible in the MapGuide viewer. As a result all the
actions are started from within the toolbar (to have one look and feel) with
invoke URL commands and showed in the taskpane. This might not have been a
good idea after all ...
As the application contains a lot of code and I will not have the time to
completely rewrite it, I hope there is a workaround possible to overcome
this.
Martin Morrison wrote:
> Look at the solution without using Mapguide for a moment. I presume you
> can query/update data in a normal web form without Mapguide.
> With the assumption that you have that working you can create a new
> frameset with two frames. One being Mapguide, the other being your web
> form that accesses the database. Pass data back and forth between the 2
> forms as needed. Use Mapguide with anonymous access and update the data
> in the web form using Integrated Security.
> This is only one way to do it, I'm sure other people will chime in with
> other methods that may be better and more efficient.
> Martin
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ismael Cams
> Sent: Wednesday, August 01, 2007 8:39 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] RE: Setting up own security with MapGuide
> These are non-geospatial databases. Basically I get the id of a feature
> (e.g.
> parcelnumber) out of the map and need to get information out of these
> databases based on the id. The kind of information is very different (e.g.
> reports, parcel information). The used database vendors are ranging from
> SQL
> Server, MS Acces to Oracle. The access is done with a direct connection
> (not
> via FDO) towards the databases.
> One thing that should be possible for example is to add new information to
> the database based on a spatial filter in the map. But not everyone is
> allowed to this, neither is everybody allowed to generate reports.
> Each of these handlings are separate .aspx pages that need to be secured
> based on the user that is logged in (windows users). Therefore I need to
> work with Integrated Security.
> Hope this gives a clear picture of what I try to achieve.
>> What type of database?
>> Sent: Wednesday, August 01, 2007 3:54 AM
>> Subject: [mapguide-users] Setting up own security with MapGuide
>> Hello,
>> I have posted this message alreay a couple of times, but until now nobody
>> could provide me with an answer.
>> As I see this as a basic functionality on IIS I assume someone should
>> have
>> already ran into this problem too.
>> I am using the .NET API to develop an application around MapGuide. This
>> application is accessing external databases. I have set up my own
>> application with Integrated Security in order to prevent unauthorized
>> users
>> from accessing this databases. Unfortunately this is causing problems
>> with
>> MapGuide. I have already tried to change the security of the MapGuide
>> directories in different ways, but I run into the problem that either the
>> viewer is not correctly working or I can not login to the MapGuide Studio
>> anymore.
>> Is it in first place possible to work with MapGuide and Integrated
>> security
>> and if yes how could this be achieved ?
>> Is it maybe possible to disable the MapGuide security somewhere in the
>> templates (note: I am providing the weblayout with user and password but
>> without any result) ?
>> This problem is keeping me busy already for months, therefore any help is
>> highly appreciated.
>> Kind regards,
>> Ismaël
>> View this message in context:
>> http://www.nabble.com/Setting-up-own-security-with-MapGuide-tf4198581s16610.html#a11941302
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Setting-up-own-security-with-MapGuide-tf4198581s16610.html#a11944773
View this message in context: http://www.nabble.com/Setting-up-own-security-with-MapGuide-tf4198581s16610.html#a11946341
