[mapguide-users] Problem creating new Layer, Map or Feature Source
Naumce Lazarevski nume at mt.net.mk
Wed Aug 1 10:29:46 EDT 2007
Yes, I'm using IIS, but i tried with enabling "Everyone" to the
MapGuideOpenSource folder.
I'll try with the security settings.
Naumce
Zak James wrote:
> There are 2 conditions that can cause this less-than-helpful error
> message to appear:
> 1. The server is responding to a request to generate a tree of the
> resources in the repository but no data are loaded.
> 2. The attempt to create a new resource failed, potentially because
> the logged in user does not have permission to create resources in the
> repository.
> Are you using IIS?
> zak
> On 8/1/07, Naumce Lazarevski <nume at mt.net.mk> wrote:
>> Hi,
>> I have reinstalled MG (1.1.0 and 1.2.0 RC1), uninstalled the anti virus
>> and
>> disabled the Firewall, but the situation is the same.
>> When I try to create Datasource, layer or map, I receive message "ERROR:
>> OK"
>> Please help.
>> Naumce
>> Zak James wrote:
>> > Naumce,
>> > This can happen if you have antivirus or firewall software installed
>> > that interferes with the ability of webstudio to communicate with the
>> > server. Try disabling anything like that temporarily to see if it
>> > clears up the problem.
>> > zak
>> > On 7/31/07, Naumce Lazarevski <nume at mt.net.mk> wrote:
>> >> Hello MG community
>> >> I have installed MG Open Source and sample data and application is Up
>> and
>> >> Running.
>> >> On one test computer creation of new layer, data source or map is Ok,
>> but
>> >> on
>> >> another computer (both with Windows XP) I can create folder in the
>> >> library,
>> >> but after creating map, layer or data source, I receive message
>> "ERROR:
>> >> OK".
>> >> Naumce Lazarevski
>> >> View this message in context:
>> http://www.nabble.com/Problem-creating-new-Layer%2C-Map-or-Feature-Source-tf4193295s16610.html#a11925022
>> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> >> _______________________________________________
>> >> mapguide-users mailing list
>> >> mapguide-users at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> > Zak James
>> > Applications and Software Development
>> > DM Solutions Group Inc.
>> > http://www.dmsolutions.ca
>> http://www.nabble.com/Problem-creating-new-Layer%2C-Map-or-Feature-Source-tf4193295s16610.html#a11945241
> Zak James
View this message in context: http://www.nabble.com/Problem-creating-new-Layer%2C-Map-or-Feature-Source-tf4193295s16610.html#a11946699
