[mapguide-users] RE: RE: Setting up own security with MapGuide
Martin Morrison
martin.morrison at edsi.com
Wed Aug 1 10:41:03 EDT 2007
Correct.
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rich Bauer
Sent: Wednesday, August 01, 2007 10:27 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] RE: RE: Setting up own security with MapGuide
I am not positive, but you are able to have basically completely separate pages in the task pane, so if you don't use any connection to MapGuide, then you should be ok because the Task pane is just a frame. Like I said, I am not positive but in my opinion it should work.
Rich
Ismael Cams wrote:
Thanks for the proposed solution Martin.
Unfortunately I thought it would be a good idea to have the application
integrated as much as possible in the MapGuide viewer. As a result all the
actions are started from within the toolbar (to have one look and feel) with
invoke URL commands and showed in the taskpane. This might not have been a
good idea after all ...
As the application contains a lot of code and I will not have the time to
completely rewrite it, I hope there is a workaround possible to overcome
this.
Martin Morrison wrote:
Look at the solution without using Mapguide for a moment. I presume you
can query/update data in a normal web form without Mapguide.
With the assumption that you have that working you can create a new
frameset with two frames. One being Mapguide, the other being your web
form that accesses the database. Pass data back and forth between the 2
forms as needed. Use Mapguide with anonymous access and update the data
in the web form using Integrated Security.
This is only one way to do it, I'm sure other people will chime in with
other methods that may be better and more efficient.
Martin
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ismael Cams
Sent: Wednesday, August 01, 2007 8:39 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: Setting up own security with MapGuide
These are non-geospatial databases. Basically I get the id of a feature
(e.g.
parcelnumber) out of the map and need to get information out of these
databases based on the id. The kind of information is very different (e.g.
reports, parcel information). The used database vendors are ranging from
SQL
Server, MS Acces to Oracle. The access is done with a direct connection
(not
via FDO) towards the databases.
One thing that should be possible for example is to add new information to
the database based on a spatial filter in the map. But not everyone is
allowed to this, neither is everybody allowed to generate reports.
Each of these handlings are separate .aspx pages that need to be secured
based on the user that is logged in (windows users). Therefore I need to
work with Integrated Security.
Hope this gives a clear picture of what I try to achieve.
What type of database?
Sent: Wednesday, August 01, 2007 3:54 AM
Subject: [mapguide-users] Setting up own security with MapGuide
Hello,
I have posted this message alreay a couple of times, but until now nobody
could provide me with an answer.
As I see this as a basic functionality on IIS I assume someone should
have
already ran into this problem too.
I am using the .NET API to develop an application around MapGuide. This
application is accessing external databases. I have set up my own
application with Integrated Security in order to prevent unauthorized
users
from accessing this databases. Unfortunately this is causing problems
with
MapGuide. I have already tried to change the security of the MapGuide
directories in different ways, but I run into the problem that either the
viewer is not correctly working or I can not login to the MapGuide Studio
anymore.
Is it in first place possible to work with MapGuide and Integrated
security
and if yes how could this be achieved ?
Is it maybe possible to disable the MapGuide security somewhere in the
templates (note: I am providing the weblayout with user and password but
without any result) ?
This problem is keeping me busy already for months, therefore any help is
highly appreciated.
Kind regards,
Ismaël
View this message in context:
http://www.nabble.com/Setting-up-own-security-with-MapGuide-tf4198581s16610.html#a11941302
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
http://www.nabble.com/Setting-up-own-security-with-MapGuide-tf4198581s16610.html#a11944773
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070801/5a064bb5/attachment.html
