[mapguide-users] Solve problem MySQL Polygon Selection
Dhirendra Kumar dhirendra.mgos at gmail.com
Thu Aug 2 05:44:17 EDT 2007
Hi Kenneth,
Once again i am asking qustion to you about Postgres/PostGIS, Kenneth I
import table in PostGIS database using shp2pgsql tool. I can create Layers
from PostGIs Database. But when i select any polygon then polygon highlight
after 4 second, So can i increase performence of polygon selection ? 300
polygon on current layer. I also provide index but problem is still same.
Any thing wrong in my process ? Please help me.
Regards,
Dhirendra Kumar
Kenneth, GEOGRAF A/S wrote:
> As someone else mentioned, the selection problem is a known bug in the
> MySQL provider.
> You have the following options:
> 1. Wait until someone fixes the problem.
> 2. Download source and fix it yourself (or perhaps pay someone to do it)
> 3. Use another provider
> If you MUST use a "real" database, I can only suggest Oracle (you have
> tried the others).
> Are there any reason that you cannot use SDF files?
> Regards, Kenneth, GEOGRAF A/S
> Dhirendra Kumar skrev:
>> Hi All,
>> Sorry for repeating this qustion. I tested MS SQL server, MySQL,
>> Postgresql/postGIS and i got result MySQL performance is better in
>> compare
>> of all, but problem in polygon selection. I want to know that, no way to
>> solve this polygon selection problem ? :(
>> PROBLEM:- When i select some polygon then near polygon get highlighted in
>> place of current selection.
>> If anyone have idea or suggestion then please help me. Thankyou in
>> Advance.
>> Regards,
>> Dhirendra Kumar
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Solve-problem-MySQL-Polygon-Selection-tf4170008s16610.html#a11961178
