[mapguide-users] Show Image On Tooltip
Dhirendra Kumar dhirendra.mgos at gmail.com
Thu Aug 2 09:11:19 EDT 2007
Hi Jhonn Jairo Vesga Cadena,
I want to know first People property reflect string or integer ? you can try
my steps
Don't worry follow steps:-
(1) First you assign <img width=210 height=130 src=[with full path, but not
image name or ID in Constant text box without greater then bracket. Then
click on New toolbar.
(2) choose people property from property combo box. and again click on new
option from toolbar.
(3) and place .jpg> your photo extension i think it will be .jpg or .gif and
click on OK button.
Regards,
Dhirendra Kumar
Jhonn Jairo Vesga Cadena wrote:
> Thanks Dhirendra, I do that, but in full Path, i need put the property
> associated to the query, because the image must be dinamic, i mean im
> showing peolpe,  im tried to write  PHOTO
> where PHOTO is a table property but doesnt work.
> I dont understand what and where concat works. Have some solution for
> this??
> Thanks-
>> you have to write  [full  image]>.
>> Regards,
>> Dhirendra Kumar
>> > Hi, i see on www.spokanemaps.com that shows an image when you put your
>> > mouse
>> > over the camera. How can i do this??? Some place to give a clue??
>> > att:
>> > Móvil:
>> > Movistar: 316-524-4147
>> > Weblog: http://www.jhonnvesga.com
>> > _______________________________________________
>> > mapguide-users mailing list
>> > mapguide-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://www.nabble.com/Show-Image-On-Tooltip-tf4201097s16610.html#a11962949
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> att:
> Móvil:
View this message in context: http://www.nabble.com/Show-Image-On-Tooltip-tf4201097s16610.html#a11964062
