[mapguide-users] Show Image On Tooltip
Jhonn Jairo Vesga Cadena jjvesga at gmail.com
Thu Aug 2 09:35:29 EDT 2007
WOW, its working now....
Thanks for the step by step, and thanks to all to take time and answer..
JJ
On 8/2/07, Rich Bauer <rdbauer at gmail.com> wrote:
>  Just to add to that, I was in the process of creating the same step by
> step, you want the " in there too I believe like src=" and .jpg">
> Rich
> Dhirendra Kumar wrote:
> Hi Jhonn Jairo Vesga Cadena,
> I want to know first People property reflect string or integer ? you can try
> my steps
> Don't worry follow steps:-
> (1) First you assign <img width=210 height=130 src=[with full path, but not
> image name or ID in Constant text box without greater then bracket. Then
> click on New toolbar.
> (2) choose people property from property combo box. and again click on new
> option from toolbar.
> (3) and place .jpg> your photo extension i think it will be .jpg or .gif and
> click on OK button.
> Regards,
> Dhirendra Kumar
> Jhonn Jairo Vesga Cadena wrote:
>  Thanks Dhirendra, I do that, but in full Path, i need put the property
> associated to the query, because the image must be dinamic, i mean im
> showing peolpe,  im tried to write  PHOTO
> where PHOTO is a table property but doesnt work.
> I dont understand what and where concat works. Have some solution for
> this??
> Thanks-
> On 8/2/07, Dhirendra Kumar <dhirendra.mgos at gmail.com> <dhirendra.mgos at gmail.com> wrote:
> you have to write  [full  image]>.
> Regards,
> Dhirendra Kumar
>  Hi, i see on www.spokanemaps.com that shows an image when you put your
> mouse
> over the camera. How can i do this??? Some place to give a clue??
> att:
> Móvil:
> Movistar: 316-524-4147
> Weblog: http://www.jhonnvesga.com
> mapguide-users mailing list
> mapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Show-Image-On-Tooltip-tf4201097s16610.html#a11962949
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> att:
> Móvil:
att:
Móvil:
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070802/6cc20a6d/attachment.html
