[mapguide-users] Export all resources in repository
Jackie Ng jackie.ng at aecsystems.com.au
Fri Aug 3 01:16:55 EDT 2007
If your feature source has the database as part of its resource data, then it
will be packaged too. Otherwise it will only be the connection that is
packaged.
- Jackie
mates wrote:
> And when the data are in a DB?? What happend?
> Kenneth, GEOGRAF A/S wrote:
>> Yes.
>> Go to the site admin:
>> http://localhost:8008/mapguide/mapadmin/login.php
>> Once loggede in, you can create packages.
>> The packages will be created in
>> C:\Program Files\MapGuideOpenSource\Server\Packages
>> That is unless you have modified something.
>> The package will contain all managed data.
>> Regards, Kenneth, GEOGRAF A/S
>> mates skrev:
>>> Is there any possibility to do this? I need reinstall my windows..
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Export-all-resources-in-repository-tf4169735s16610.html#a11977592
