[mapguide-users] MGOS 1.2.0 On Linux: Error 559 MgFdoException Whe Selecting ODBC DSN
James Card James.Card at calcad.com
Fri Aug 3 16:13:53 EDT 2007
On Fri, 03 Aug 2007 12:33:38 -0700, Zak James <zak4ms at gmail.com> wrote:
> In the providers.xml file within the fdo directory, there should be an
> entry for ODBC. You need to make sure any shared libraries it references
> are present. I don't have odbc setup on linux, but this is usually a
> good troubleshooting step when a provider fails to execute.
Thanks Zak! Indeed the libFdoODBC.so library is missing. Looks like I'll
be rebuilding FDO.
James Card
209 578-5580
