[mapguide-users] Solve problem MySQL Polygon Selection
Dhirendra Kumar
dhirendra.mgos at gmail.com
Sat Aug 4 03:31:23 EDT 2007
Hi Kenneth,
I want your help once agian, Both are using same OGR provider (3.2.2) but
you have not any problem, So i want know you are using which version of
MGOS and OGR Provider. In Earlier reply you mentioned some OGR version have
problem, So tell me which verion is better and working fine with which
version of MGOS. Please help me. I am waiting for your replay. Thankyou in
Advance.
Regards,
Dhirendra Kumar
Kenneth, GEOGRAF A/S wrote:
> I'm sorry, but I never had that problem with OGR,
> and I have no idea what may be causing it.
> Regards, Kenneth, GEOGRAF A/S
> Dhirendra Kumar skrev:
>> Hi Kenneth,
>> Now i established connection with OGR provider and MGOS1.2.0RC2, i can
>> make
>> layer also Performance is good. but when i select any polygon then
>> polygon
>> not get selected. I established connection using OGR provider
>> (OGRProvider-3.2.2.win32.zip). Kenneth please help me once agian.
>> Thankyou
>> in Advance
>> Regards,
>> Dhirendra Kumar
>>> I have no experience with the PostGIS provider.
>>> I had no delays using OGR for PostGIS data.
>>> Regards Kenneth, GEOGRAF A/S
>>>> Hi Kenneth,
>>>> I make layer using PostGIS provider not OGR Provider. No problems with
>>>> tooltips, it is working fine. only problem with polygon selection
>>>> taking
>>>> 4
>>>> second to highlight. OGR Provider can solve this problem ? Yes Kenneth
>>>> before displaying layer or map server use 100% CPU and before tool tips
>>>> displaying server use 10-20% CPU. Any way to overcome this problem ?
>>>> Regards,
>>>> Dhirendra kumar
>>>>> I recall that there was a problem with selection/info in some version
>>>>> of
>>>>> the OGR.
>>>>> What version of the OGR provider do you use?
>>>>> Does your server use 100% CPU before displaying?
>>>>> Is the problem the same with tooltip's ?
>>>>>> Hi Kenneth,
>>>>>> Once again i am asking qustion to you about Postgres/PostGIS, Kenneth
>>>>>> I
>>>>>> import table in PostGIS database using shp2pgsql tool. I can create
>>>>>> Layers
>>>>>> from PostGIs Database. But when i select any polygon then polygon
>>>>>> highlight
>>>>>> after 4 second, So can i increase performence of polygon selection ?
>>>>>> 300
>>>>>> polygon on current layer. I also provide index but problem is still
>>>>>> same.
>>>>>> Any thing wrong in my process ? Please help me.
>>>>>> Regards,
>>>>>> Dhirendra Kumar
>>>>>>> As someone else mentioned, the selection problem is a known bug in
>>>>>>> the
>>>>>>> MySQL provider.
>>>>>>> You have the following options:
>>>>>>> 1. Wait until someone fixes the problem.
>>>>>>> 2. Download source and fix it yourself (or perhaps pay someone to do
>>>>>>> it)
>>>>>>> 3. Use another provider
>>>>>>> If you MUST use a "real" database, I can only suggest Oracle (you
>>>>>>> have
>>>>>>> tried the others).
>>>>>>> Are there any reason that you cannot use SDF files?
>>>>>>>> Hi All,
>>>>>>>> Sorry for repeating this qustion. I tested MS SQL server, MySQL,
>>>>>>>> Postgresql/postGIS and i got result MySQL performance is better in
>>>>>>>> compare
>>>>>>>> of all, but problem in polygon selection. I want to know that, no
>>>>>>>> way
>>>>>>>> to
>>>>>>>> solve this polygon selection problem ? :(
>>>>>>>> PROBLEM:- When i select some polygon then near polygon get
>>>>>>>> highlighted
>>>>>>>> in
>>>>>>>> place of current selection.
>>>>>>>> If anyone have idea or suggestion then please help me. Thankyou in
>>>>>>>> Advance.
>>>>>>>> Regards,
>>>>>>>> Dhirendra Kumar
>>>>>>> _______________________________________________
>>>>>>> mapguide-users mailing list
>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Solve-problem-MySQL-Polygon-Selection-tf4170008s16610.html#a11994528
