[mapguide-users] libxerces error on FC6
Ray Holtz ray at rayholtz.com
Sun Aug 5 21:04:37 EDT 2007
Rex, thanks for the tip, but it did not help.  I downloaded the latest
libpng 1.2.18 and it build fine without errors.  I reran configure for
mapguide, and then make and it errored out with the same errors.  Has
anyone else seen this and gotten it fixed, or know how to get past it?
Thanks!
Rex Szeto (Intern) wrote:
> Hi Ray,
> This error you are getting is not related to the libxerces warning.
> I had the same problem trying to build on RHEL4 before.
> The OEM build script builds an old version of PNG library (bundled with
> GD).
> You have to download the latest version of libpng, build and install it.
> That fixed the problem for me.
> Good luck,
> Rex
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ray Holtz
> Sent: Friday, August 03, 2007 1:29 PM
> To: MapGuide Users Mail List
> Subject: [mapguide-users] libxerces error on FC6
> Hi all (again) I hate being a pain over and over asking for help, but
> here I am again.  I just ran "./configure --enable-webtier=no" and I am
> now running "make" and it errors out with the error below.
> Any ideas on how to get past it? Thanks!
> /usr/bin/ld: warning: libxerces-c.so.27, needed by
> /usr/local/maptemp/mapguide/Server/src/Services/Drawing/.libs/libMgServe
> rDrawingService.so,
> may conflict with libxerces-c.so.25
> /usr/local/maptemp/mapguide/Common/Renderers/.libs/libMgRenderers.so:
> undefined reference to `gdImagePng'
> undefined reference to `gdImagePngPtr'
> undefined reference to `gdFontCacheSetup'
> undefined reference to `gdImageCreateFromPng'
> undefined reference to `gdFontCacheShutdown'
> undefined reference to `gdImageCreateFromPngPtr'
> collect2: ld returned 1 exit status
> make[3]: *** [mgserver] Error 1
> make[3]: Leaving directory `/usr/local/maptemp/mapguide/Server/src/Core'
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory `/usr/local/maptemp/mapguide/Server/src'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/usr/local/maptemp/mapguide/Server'
> make: *** [all-recursive] Error 1
> You have mail in /var/spool/mail/root
> [root at RB-MapGuide mapguide]#
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
