[mapguide-users] Trying to Create a Theme but get "Parameter
Not Found"
Jackie Ng
jackie.ng at aecsystems.com.au
Mon Aug 6 02:26:21 EDT 2007
Are you using MGOS 1.1 or lower? Studio can't generate themes on secondary
table.
However, you should be able to create the style rules from the secondary
table one-by-one without a problem.
- Jackie
PhilipM wrote:
> I am trying to create a theme to a secondary table. I have created the
> join, but when I try to create the theme I keep getting a message saying
> "Parameter Not Found". Has anyone else had this problem? Does anyone
> know a solution?
> I am able to create a tooltip that displays the property I want to theme
> against. It is just when I create the theme that it does not want to
> work.
View this message in context: http://www.nabble.com/Trying-to-Create-a-Theme-but-get-%22Parameter-Not-Found%22-tf4222200s16610.html#a12011625
