[mapguide-users] RE: IE, AJAX and Tooltip Images
Chris Claydon
chris.claydon at autodesk.com
Tue Aug 7 11:42:17 EDT 2007
Try using curly braces instead of brackets to enclose the "return
false;" call. i.e.
if(x == lastposx && y == lastposy)
return false;
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ben_D
Sent: August 6, 2007 4:12 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: IE, AJAX and Tooltip Images
Does anyone know if this works with version 1.1.0?
I've put this in:
if(x == lastposx && y ==lastposy)
return false;
and my map will not load (firebug comes up with a "OnMouseMove error"
funnily enough...). If I comment it out, my map will load.
Thanks!
Seen this?
http://trac.osgeo.org/mapguide/changeset/1412
Seems like it would be easy to apply to an existing site which was
having
this problem...
Jason
View this message in context:
http://www.nabble.com/IE%2C-AJAX-and-Tooltip-Images-tf3390727s16610.html
#a12025232
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
