[mapguide-users] RE: How to enable markup using Design review
Joel Carranza
jec at gatekeeper.com
Tue Aug 7 15:43:20 EDT 2007
I've been playing around with the EPlots generated out of the sample
application by Map Guide (Open Source 1.2RC2), with the eye towards doing
markup in ADR. One thing I noticed was that when the maps open in Autodesk
design review, they come up in "Unknown" units. Consequently, I am unable
to use the measure tools to produce a meaningfull result. It seems clear
that the actual units are in "page space", because when I measure across the
entire width of the page, I get about 8.5
I realize that the ePlot functionality is more centered around printing.
However, is there a way to generate a DWF out of the MapGuide which is more
"geo-aware", which contains inside the DWF information about the map extent
which the DWF covers, and where ADR can make use of tools like Measure and
their geo-referencing ability?
Thanks,
Joel
Gatekeeper Systems
Jackie Ng wrote:
> What walt meant, was to use the MapGuide RenderingService APIs to create
> your EPlot DWFs.
> - Jackie
> christophe_geomap wrote:
>> I try to save a map with the IAdDwfViewer::SaveAs method, but it doesn't
>> work !
>> With the IAdDwfViewer::ExecuteCommandEx("SAVEAS",0), i can save the DWF
>> but i don't know how to catch the new filename.
>> Do you have any idea ?
>> Christophe
>> Walt Welton-Lair wrote:
>>> The markup functionality in Design Review is not used by MapGuide. When
>>> using ADR or DWF Viewer to view MapGuide maps, you're using the EMap
>>> viewer functionality. EMap does not support markups.
>>> MapGuide does let you save your current view of a map as an EPlot DWF.
>>> You could then open that EPlot in ADR and add markups.
>>> Walt
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
>>> Sent: Thursday, January 25, 2007 10:21 AM
>>> To: mapguide-users at lists.osgeo.org
>>> Subject: [mapguide-users] How to enable markup using Design review
>>> I have installed the design review software instead of the dwf viewer.
>>> When using mapguide with dwf i don't have access to the markup tools.
>>> If i open the about command, it tells me that i'm really using the
>>> "design
>>> review"
>>> So my question is "How to enable markup using Design review in mapguide"
>>> View this message in context:
>>> http://www.nabble.com/How-to-enable-markup-using-Design-review-tf3097065
>>> s16610.html#a8598618
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/How-to-enable-markup-using-Design-review-tf3097065s16610.html#a12040997
