[mapguide-users] How Can I load SDF
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Aug 9 03:50:31 EDT 2007
The FDO has no dependency to the license, so there is no problem with a
trial version.
It is not enough to reference the Dll's. Some of the required Dll's are
NOT .Net dlls and cannot be referenced.
In fact the .Net dlls merely call the native Dll's.
You must manually copy ALL the dll's from a working MapGuide's FDO
folder into the folder where your program runs.
This is usually a folder named "bin\debug". If it still does not work,
try opening the different dll's with dependency walker.
www.dependencywalker.com
That will show you what dll files you are missing.
Regards, Kenneth, GEOGRAF A/S
akramany skrev:
> Thank you Mr.Kenneth , I had added all DLLs in VB.NET reference from MapGuide
> installation's FDO folder but the same error still there , I think this
> maybe happened because I'm using trial version of Mapguide or what ?!
> Kenneth, GEOGRAF A/S wrote:
>> There are a number of Dll's that are needed for FDO to work.
>> You should ALL the files from a working MapGuide installation's FDO
>> folder,
>> into the folder you reference the .Net wrapper from.
>> The error 0x8007007E means "File not found",
>> indicating that you are missing some files.
>> As to the error with Studio; the load procedure is mostly unrelated
>> to the MapGuide server, so you should ask Autodesk about that problem.
>> There is no need/way to register the FDO dll's as they are not ActiveX
>> dll's.
>> akramany skrev:
>>> When I import FDO as a reference in VB.NET and connect to SDF database
>>> format
>>> I have continual error  (Exception from HRESULT: 0x8007007E)  .
>>> Also I have continual error (Exception from HRESULT: 0×800700c1) when I
>>> load
>>> SDF or SHP data with Autodesk MapGuide studio , this problem since one
>>> month
>>> I don’t reach to the solution , kindly I would like to get the right
>>> solution in this matter if any one know .
>>> How can I Register FDO DLL ?!!
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070809/89ed61ad/attachment.html
