[mapguide-users] How Can I load SDF
akramany
asm at cad-gis.com
Thu Aug 9 10:55:46 EDT 2007
Hi Rahul ,
you can solve you problem by these steps :
* If you using MapGuide Server you should install it with windows 2003
server without SP2
* If you use ASP.NET with IIS in same machine you should do this steps
1. Click Start, click Run, type cmd in the Open box, and then click OK.
2. Switch to the Drive:\Windows\Microsoft.Net\Framework\v1.1.4322 folder. In
this folder, Drive is the drive where Windows is installed. To do this, type
the following line at the command prompt, and then press ENTER:
cd Drive:\windows\microsoft.net\framework\v1.1.4322
3. Add the appropriate permissions to the Network Service group for the
Temporary ASP.NET Files folder. To do this, type the following line, and
then press ENTER:
aspnet_regiis -ir
Note For more information about the difference between the -ir command-line
option and the -i command-line option, visit the following Microsoft Web
site:
http://msdn2.microsoft.com/en-us/library/k6h9cz8h(vs.71).aspx
(http://msdn2.microsoft.com/en-us/library/k6h9cz8h(vs.71).aspx)
4. Type exit, and then press ENTER to quit the command prompt.
* in web.config make <authentication mode="None"/>
View this message in context: http://www.nabble.com/How-Can-I-load-SDF-tf4151735s16610.html#a12073921
