[mapguide-users] Site Open Problem
gom
gord.mckenzie at canam.com
Thu Aug 9 17:26:01 EDT 2007
I have created a small app, in vb.net, that changes the default map and
weblayout to get cutom extents on startup. Based on a url parameter I use
the default layout and map or I modify the resources and make session
versions of the layout and map. I get all the desired results.
However, after it is used for awhile, sorry I don't have exact useage counts
or times, but several times a day the application will quit working with an
mgunclassified exception error. In the debugger I can see that it fails on
the site.open call. I believe I am disposing of objects as needed.
Restarting the Mapguide Server and IIS does not immediatley resolve the
problem. Neither does restarting the entire server. However, if I log in
to Studio and open the weblayout, the site becomes available again
immediately. I am suspecting maybe some sort of problem with sessionstate
or something but I would think a server reset would take care of that.
Any ideas that might help me figure out whats going on?
Mapguide 1.1.1
IIS 6
Windows 2003
vb.net
Thanks
View this message in context: http://www.nabble.com/Site-Open-Problem-tf4245318s16610.html#a12081076
