[mapguide-users] I can not login to mapguide Administrator
Sitefor first time :(
Sebastian Bedin
sbedin at fyctecnologia.com.ar
Fri Aug 10 10:58:38 EDT 2007
Bug MGOS.
Si se realizar una consulta desde una web al MapGuideServer, mientras tienes
abierto el MapGuideStudio (y estas guadando cambios) se puede corromper los
archivos del repositorio ( Server/Repositories/ ). En la pagina de Autodesk
recomiendan hacer backup del contenido de dicha carpeta. Si no hiciste
backup, tenes que reinstalar el MGOS y las extenciones. Tambien combiene
hacer packages de los archivos del Studio.
Recomendacion: Trabajar con la version MGOS 1.1 !!! (es muy estable)
Espero que al traducir esto lo entiendas. Saludos,
Sebastian Bedin
www.odisey.com.ar
ARGENTINA
PD: http://www.traducegratis.com/
----- Original Message -----
To: <mapguide-users at lists.osgeo.org>
Sent: Thursday, August 09, 2007 9:54 PM
Subject: Re: [mapguide-users] I can not login to mapguide Administrator
> You installed 1.2 after uninstalling 1.1?
> Try killing all the php-cgi.exe processes in the Task Manager. They may
> have
> been leftovers from the 1.1 installation.
> - Jackie
> kuba_debek wrote:
>> Hello
>> So I see many post about this problem but still I can not login to my
>> mapguide Site Administrator
>> (http://localhost:8008/mapguide/mapadmin/login.php)
>> login 'Administrator' and pass 'admin' isn't correct.
>> I have WINXP SP2:
>> 1. apache_2.0.59
>> 2. php-5.2.3
>> 3. MgServerSetup-1.2.0RC2
>> 4. MgWebServerExtensionsSetup-1.2.0RC2
>> All Apache Mapguide services are runnig
>> I had 1.1.0 too :(
>> I restarted mapguide server service:(
>> I tryed "Administrator" and "administrator" :(
>> Can you help me?
>> Can it depends of apache or php version?
>> Kuba
> http://www.nabble.com/I-can-not-login-to-mapguide-Administrator-Site-for-first-time-%3A%28-tf4245746s16610.html#a12083605
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.5.476 / Virus Database: 269.11.11/944 - Release Date:
> 09/08/2007 02:44 p.m.
