[mapguide-users] RE: Introducing Fusion ...
bizna bizna at hotmail.com
Mon Aug 13 13:25:20 EDT 2007
Thanks Max,
I found out that there are also directions included in the fusion sample
that I missed ...
1. Read the HTML installation document included at:
fusion\docs\installation.html
2. To see the two fusion samples, assuming you are testing on a local
installation of MGOS, go to the following urls:
   	simple sample application:
	http://localhost:8008/mapguide/fusion/samples/mapguide/simple/index.html
    standard sample application:
	http://localhost:8008/mapguide/fusion/samples/mapguide/standard/index.html
Rahul-2 wrote:
> you have to put the fusion folder in the webserver extension folder
> F:\Program Files\MapGuideOpenSource\WebServerExtensions\www or whatever as
> per your settings and then configure the fusion samples as per your system
> settings.(Refer to the Installation docs ).
View this message in context: http://www.nabble.com/Introducing-Fusion-...-tf4137298s16610.html#a12130444
