[mapguide-users] Error while trying to join with feature source
Joel Carranza
jec at gatekeeper.com
Mon Aug 13 20:12:55 EDT 2007
I'm having a similair problem. I have setup a SDF datasource which displays
correctly in mapguide when used by itself. However, now I want to join it to
an ODBC datasource (for tooltip and labeling). But I'm not sure if I want to
create a join from the SDF or from the ODBC datasource. Neither seem to work
for me right now.
When I try to create a join from the SDF page, I get the following error
"The current feature source has no feature classes, and cannot support
joins"
When I try and create a join from the ODBC page, I can create a join and
everything looks good. However, when I try and create a layer based on that
joined datasource, nothing is available in the Geometry column. So now I am
pretty much lost.
Joel Carranza
Gatekeeper Systems
Abhinav Katoch wrote:
> Hi,
> I'm trying to join an access database via ODBC with an SDF source in
> MapGuide studio and keep getting an error message in Mapguide Studio
> saying
> "This type of feature source cannot be added as a join.Please try again".
> I
> was wondering if anybody had any insight to get around this issue.
> Any help would be much appreciated.
> Thanks,
> -Abhinav
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Error-while-trying-to-join-with-feature-source-tf4256880s16610.html#a12136611
