[mapguide-users] SQL Server2005 & MapGuide Studio2007
Kenneth, GEOGRAF A/S
ks at geograf.dk
Mon Aug 20 05:37:28 EDT 2007
I have experienced an error that looks the same, but using Access databases.
It appears that studio caches some information regarding the table layout.
When the database changes, it is no longer possible to use the
datasource for any purpose.
Merely deleting the datasource and recreating it, does not work.
Try to delete the datasource.
Quit studio.
Create the datasource.
It should now work correctly.
Regards, Kenneth, GEOGRAF A/S
Rahul skrev:
> Hi All,
> Currently i am working with SQL Server 2005 and already
> created the datastore and geospatial table using the Map3D 2007 ,I can
> view the layers and can do online editing ,updting features etc using
> the Map3D 2007.
> After working fine in Map3D I tried to figure it out with Autodesk
> MapGuide Studio 2007 and created a connection using the MGE 2007 with
> FDO Provider for SQL Server,I succesfully able to create the
> connection and use to get Data Resource and Feature Class with
> properties list from the SQL server but when i try to perfom theming
> and want to add rule using the condition and value(Get) ,it use to
> give error *an Exception Occured in FDO Component.Table Does not exits
> for class'abc:Roads*', although the table is available in the database
> and i can easily update and edit using the Map3D 2007.
> I also unable to view the layers in the Map or Layout Preview of the
> MapGuide Studio,I am bemused and any kind of reference/support will be
> of great help.
> Cheers
> Max !!
> Sick sense of humor? Visit Yahoo! TV's Comedy with an Edge
> <http://us.rd.yahoo.com/evt=47093/*http://tv.yahoo.com/collections/222>to
> see what's on, when.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070820/967cbf1c/attachment.html
