[mapguide-users] Tile Pre-rendering 1.2 .NET
Zac Spitzer
zac.spitzer at gmail.com
Fri Aug 24 10:44:14 EDT 2007
Please file a bug on this, you have some very specific detail here
which should make the investigation and resolution much easier
http://trac.osgeo.org/mapguide/
z
On 8/24/07, ZoffoMan <zoffo at adelphia.net> wrote:
> I wrote a .NET "tiling engine" for 1.2. It gets all the scales and figures
> out the tiles to generate, etc. and walks the Base Layer. However after
> making 58 correct tiles it dies. I get a MgConnectionFailedException.
> It calls the new 1.2 GetTile(mapDef, baseName, x, y, scale) method of the
> TileService.
> I thought it was because I was not originally using sessions with my
> userInfo. I changed it to use sessions and get the same results. I even
> tried to make it reconnect when getting this error. However, I have to
> restart the MapGuide service to use MapGuide again.
> Any thoughts?
> Is this something that is solved in the source tree that I could build?
> View this message in context: http://www.nabble.com/Tile-Pre-rendering-1.2-.NET-tf4323844s16610.html#a12313282
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
http://zacster.blogspot.com/
+61 3 9018 5778 (voip via my pc)
+61 405 847 168 (aussie moible)
