[mapguide-users] MgLayerBase::GetClassDefinition fails on MGOS1.2RC2
Rex Szeto (Intern) Rex.Szeto at autodesk.com
Fri Aug 24 11:37:37 EDT 2007
Hi Takashige,
In your code, instead of using MgLayerBase, cast it to MgLayer.
MgLayer layer = (MgLayer)GetLayerByName(map, layerName);
MgClassDefinition classDef = layer.GetClassDefinition();
Regards,
Rex
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Takashige
Nakagawa
Sent: Thursday, August 23, 2007 11:58 PM
To: MapGuide Users Mail List
Subject: [mapguide-users] MgLayerBase::GetClassDefinition fails on
MGOS1.2RC2
Hi, all.
Now I'm writing some test programs on MGOS 1.2 RC2. In the codes below,
MgLayerBase::GetClassDefinition causes an exception "Class not found."
When I use MgFeatureService ( as I do on Ver 1.1 ) instead , everything
works fine.
Is there something I do wrong?
Regards.
Takashige
----Codes-------------------------------------------
    String doTest()
        NameValueCollection parameters = GetRequestParameters(Request);
        String sessionId = GetParameter(parameters, "_session_id_");
        String mapName = GetParameter(parameters, "_mapname_");
        String layerName = GetParameter(parameters, "_layername_");
        MgUserInformation userInfo = new MgUserInformation(sessionId);
        MgSiteConnection siteConnection = new MgSiteConnection();
        siteConnection.Open(userInfo);
        MgMap map = new MgMap(siteConnection);
        map.Open(mapName);
        MgLayerBase layer = GetLayerByName(map, layerName);
        // Version1.1 ******* Works fine on ver 1.2 !
        //MgFeatureService featureService = _
siteConnection.CreateService(MgServiceType.FeatureService) as
MgFeatureService;
        //MgClassDefinition classDef =
GetClassDefinitionV11(featureService,
layer);
        // Version1.2  ******* Fails!  What's wrong??
        return layerName;
    MgClassDefinition GetClassDefinitionV11(MgFeatureService
featureService,
MgLayerBase layer)
        String featureSourceId = layer.GetFeatureSourceId();
        MgResourceIdentifier featureSourceResId = new
MgResourceIdentifier(featureSourceId);
        String featureClassName = layer.GetFeatureClassName();
        String[] schemaClass = featureClassName.Split(new char[] { ':'
        String schemaName = schemaClass[0];
        String className = schemaClass[1];
        return featureService.GetClassDefinition(featureSourceResId,
schemaName, className);
    NameValueCollection GetRequestParameters(HttpRequest request)
        if ("POST" == request.HttpMethod)
            return request.Form;
        else
            return request.QueryString;
    String GetParameter(NameValueCollection parameters, String name)
        String strval = parameters[name];
        if (null == strval)
            return "";
        return strval.Trim();
    MgLayerBase GetLayerByName(MgMap map, String layerName)
        MgLayerCollection layers = map.GetLayers();
        MgLayerBase layer = null;
        for (int i = 0; i < layers.GetCount(); i++)
            MgLayerBase nextLayer = layers.GetItem(i);
            if (nextLayer.GetName() == layerName)
                layer = nextLayer;
                break;
        return layer;
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
