[mapguide-users] Missing Coordinate Systems
Kenneth, GEOGRAF A/S
ks at geograf.dk
Fri Aug 31 08:37:43 EDT 2007
On multiple installations of MapGuide OS 1.2 RC2, there are no
coordinate systems installed.
If I access the http://<hostname>/mapguide/mapagent/index.htm, choose
Coordinate System and EnumerateCategories i get:
<StringCollection><Item>Arbitrary X-Y Coordinate Systems</Item></StringCollection>
Trying the same on the "Live Application Gallery servers gives:"
<StringCollection><Item>Arbitrary X-Y Coordinate Systems</Item><Item>EPSG</Item><Item>World/Continental</Item></StringCollection>
The latter is the desired result.
For any server, the "GetBaseLibrary" call returns: "PROJ4 Coordinate
System Library"
I can see no errors in any of the log files.
It might be related to ticket 209,
http://trac.osgeo.org/mapguide/ticket/209.
Tracking it, reveals that a registry entry
"HKLM\SOFTWARE\MapGuideOpenSource\CoordinateSystem" specifies:
C:\Program Files\MapGuideOpenSource\WebServerExtensions\www\nad
Where the PROJ_LIB specifies:
PROJ_LIB=C:\Program Files\MapGuideOpenSource\Server\nad
I have no idea where each entry comes from, as both machines have had
1.1 installed.
However, the "categories.txt" is NOT located in
but can be copied from:
C:\Program Files\MapGuideOpenSource\Server\bin
Copying the file makes the coordinate categories appear.
Regards, Kenneth, GEOGRAF A/S
