[mapguide-users] Problem in loading SDF data in Mapguide Webstudio
Parvatha kpeswari at indiainfo.com
Sat Dec 1 00:56:00 EST 2007
Hi Kenneth,
 Thanks for your reply. The problem is not with sdf and with upload data
only. With studio preview its working well. But i want to understand the
need of web studio and its limitations.
Thanks and Regards
Parvatha
Kenneth, GEOGRAF A/S wrote:
> You should use the "Load Procedures" from within MapGuide Studio.
> The load procedures are missing from WebStudio, because the Load
> procedures read proprietary data formats and converts them to SDF for
> use in the server.
> WebStudio is missing the "Load Procedures" and currently an editor for
> WebStudio.
> What you describe means that there is no spatial data inside the loaded
> SDF files.
> Please try again with different data. If you suspect that the problem is
> with the load procedures,
> you can ask Autodesk for support.
> Regards, Kenneth, GEOGRAF A/S
> Parvatha skrev:
>> Can anybody help me to solve this issue in webstudio?
>> Parvatha wrote:
>>> Hi
>>>  I am new to MapGuide Opensource. I have downloaded version 1.2 of MGOS
>>> and it has got webstudio in that. I am using .NET 2 and able to see the
>>> sample data.
>>>  My problem is when i try to load SDF data the sytem takes few seconds
>>> then in data file resources window its showing the file name. But when i
>>> create one layer and try to give this as data source its not showing any
>>> feature class and geometry. I dont know what is the problem in loading
>>> the
>>> sdf data. Can anybody please help me to solve this issue.
>>>  I have downloaded the trail version of MG studio preview also. With
>>> that
>>> I am able to do all these things. But basically I want to understand the
>>> need of webstudio and the limitations. Is it necessary to do everything
>>> in
>>> MG studio only? then what is the purpose of web studio?
>>> Thanks and waiting for the response
>>> Parvatha
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Problem-in-loading-SDF-data-in-Mapguide-Webstudio-tf4896513s16610.html#a14102518
