[mapguide-users] Problem in loading SDF data in Mapguide Webstudio
Parvatha kpeswari at indiainfo.com
Sun Dec 2 22:51:20 EST 2007
Hi Kenneth,
 Thanks for your reply. Now its clear.
Regards
Parvatha
Kenneth, GEOGRAF A/S wrote:
> MapGuide Studio is a ful product with Autodesk support.
> WebStudio is an opensource web based product.
> In essence they accomplish the same task, however WebStudio does not
> have any direct funding.
> This means that it will not always be stable/updated, unless some
> volunteer does some work on it.
> Currently there is no editor for WebLayouts in WebStudio.
> This limitiation is quite severe, as the AJAX and DWF viewers are based
> on a WebLayout.
> In other words, you will not be able to build a solution that works
> right away, using only WebStudio.
> Secondly, there is no legal way for an opensource product to support
> proprietary formats (such as DWG and ArcSDE).
> MapGuide Studio can overcome this limitation, since it is not open source.
> Regards, Kenneth, GEOGRAF A/S
> Parvatha skrev:
>> Hi Kenneth,
>>  Thanks for your reply. The problem is not with sdf and with upload data
>> only. With studio preview its working well. But i want to understand the
>> need of web studio and its limitations.
>> Thanks and Regards
>> Parvatha
>>> You should use the "Load Procedures" from within MapGuide Studio.
>>> The load procedures are missing from WebStudio, because the Load
>>> procedures read proprietary data formats and converts them to SDF for
>>> use in the server.
>>> WebStudio is missing the "Load Procedures" and currently an editor for
>>> WebStudio.
>>> What you describe means that there is no spatial data inside the loaded
>>> SDF files.
>>> Please try again with different data. If you suspect that the problem is
>>> with the load procedures,
>>> you can ask Autodesk for support.
>>> Parvatha skrev:
>>>> Can anybody help me to solve this issue in webstudio?
>>>> Parvatha wrote:
>>>>> Hi
>>>>>  I am new to MapGuide Opensource. I have downloaded version 1.2 of
>>>>> MGOS
>>>>> and it has got webstudio in that. I am using .NET 2 and able to see
>>>>> the
>>>>> sample data.
>>>>>  My problem is when i try to load SDF data the sytem takes few seconds
>>>>> then in data file resources window its showing the file name. But when
>>>>> i
>>>>> create one layer and try to give this as data source its not showing
>>>>> any
>>>>> feature class and geometry. I dont know what is the problem in loading
>>>>> the
>>>>> sdf data. Can anybody please help me to solve this issue.
>>>>>  I have downloaded the trail version of MG studio preview also. With
>>>>> that
>>>>> I am able to do all these things. But basically I want to understand
>>>>> the
>>>>> need of webstudio and the limitations. Is it necessary to do
>>>>> everything
>>>>> in
>>>>> MG studio only? then what is the purpose of web studio?
>>>>> Thanks and waiting for the response
>>>>> Parvatha
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Problem-in-loading-SDF-data-in-Mapguide-Webstudio-tf4896513s16610.html#a14123484
