[mapguide-users] Not much luck with ogr or postgis on Ubuntu
Jo Cook
j.cook at OXFORDARCH.CO.UK
Mon Dec 3 05:07:42 EST 2007
I made the change, rebuilt the whole fdo stack (including updating from the
svn) and it didn't seem to make any difference. When I run ldd -r
libPostGISProviders.so I still get the same error.
Many thanks
Jo
gregboone wrote:
> Please generate an FDO Ticket to track this issue so it can be resolved in
> an upcoming build/release.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jack Lee
> Sent: Friday, November 30, 2007 1:09 PM
> To: MapGuide Users Mail List
> Subject: RE: [mapguide-users] Not much luck with ogr or postgis on Ubuntu
> Hi,
> The crypt library seems to be missing from PostGIS/Src/Makefile.am
> You can try changing
> -lpq
> to
> -lpq \
> -lcrypt
> in Makefile.am and rebuild.
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Joanne Cook
> Sent: Freitag, 30. November 2007 12:35
> To: mapguide-users at lists.osgeo.org
> Hi All,
> I seem to be unable to answer mailing list messages in nabble at the
> moment, and only get the daily digest otherwise, so here goes:
> 1: Dave suggested there should be Provider.so files in the FDO/bin
> directory but I don't have that- only /usr/local/fdo-3.3.0/lib and they
> are all in there. Doing a search for one of the other providers seems to
> suggest that's the only location for all of them, which may be wrong?
> 2: Running ldd -r on libPostGISProvider.so gives me the following line
> that I don't get when I run any of the others (including ogr): undefined
> symbol: crypt (./libPostGISProvider.so)
> 3: Not sure how to use LD_LIBRARY_PATH, but running echo $LD_LIBRARY_PATH
> doesn't give me anything
> Thanks for all the replies
> Jo
> Message: 40
> Date: Fri, 30 Nov 2007 08:38:14 -0800
> From: "Jason Birch" <Jason.Birch at nanaimo.ca>
> Ubuntu
> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>,
> <fdo-internals at lists.osgeo.org>
> Message-ID:
> <8E468917B01800408B91984428BE03DD072A5C74 at starfish.nanaimo.ca>
> Content-Type: text/plain; charset="US-ASCII"
> I ran into the same problem the last time I checked. Perhaps we need to
> put the PostGIS and OGR shared libraries into the include path before
> running MapGuide or something? I unfortunately don't know enough about
> this stuff works on *nix to be able to figure out where to start. Is
> there something equivalent to depends.exe on windows?
> Are the .so files for the drivers to talk to PostGIS or OGR in some
> directory other than the FDO/bin directory? If so then add the path to the
> LD_LIBRARY_PATH and try again. Otherwise copy the .so files into the
> FDO/bin folder.
> At least that's how the other FDO providers work. The.so files need to be
> in the same folder or in the system path.
> Dave
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: Friday, November 30, 2007 9:38 AM
> To: MapGuide Users Mail List; fdo-internals at lists.osgeo.org
> I can't start my VM right now, but if you look in your FDO directory,
> can you see whether the appropriate provider library files were built
> for these?
> Any FDO folks have any ideas about this?
> Jason
> Files attached to this email may be in ISO 26300 format (OASIS Open
> Document Format). If you have difficulty opening them, please visit
> http://iso26300.info for more information.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/RE%3A-Not-much-luck-with-ogr-or-postgis-on-%09Ubuntu-tf4924763s16610.html#a14127003
