[mapguide-users] feature class in mapguide studio
    Jackie Ng
    jackie.ng at aecsystems.com.au
    Tue Dec  4 02:14:21 EST 2007
I get this problem when using ODBC to SQL Server (2000/2005)
My theory is that it is some bug or feature of FDO that is caching the
database schema information. As a result, schema changes (eg. Add/Removed
table. Add/Removed/Renamed columns in a table) are not reflected
immediately.
- Jackie
JotaroKujo wrote:
> dorra2007 wrote:
>> but when I want to update my database (I added  new spatial table to the
>> postgis database), the featureSource is not updated, and I can't create a
>> new layer using the new table (because it's not displayed in the feature
>> class list.)
> I have found the same problem with Oracle 10g (I use the Autodesk
> commercial FDO).
> If you delete the connection, and recreate it...you will find the new
> tables in the list.
> May be when a connection is created, the server creates a file containing
> the database catalogue structure.
View this message in context: http://www.nabble.com/feature-class-in-mapguide-studio-tf4935604s16610.html#a14145738
