[mapguide-users] feature class in mapguide studio
Zac Spitzer
zac.spitzer at gmail.com
Tue Dec 4 06:34:36 EST 2007
in the old mapguide, if you had very long table names, the ide
(mapguide author?) would have
problems unless you made them shorter.... can you show us a list of
the table names?
On Dec 4, 2007 8:13 PM, dorra2007 <dorrdor at yahoo.fr> wrote:
> I have deleted and recreated the connection, sometimes have one new table
> reflected in mapguide studio, sometimes not.
> The most blocking thing is that in any case, the number of tables reflected
> doesn't exceed four. I mean, when I have more than four tables (7 for
> example), I have, as maximum, only four tables reflected in mapguide studio
> (if, of course, I succeed to get them in mapguide studio.)
> Have you encountered such problem (a max number of tables that can be
> displayed.)
> JotaroKujo wrote:
> > dorra2007 wrote:
> >> but when I want to update my database (I added new spatial table to the
> >> postgis database), the featureSource is not updated, and I can't create a
> >> new layer using the new table (because it's not displayed in the feature
> >> class list.)
> > I have found the same problem with Oracle 10g (I use the Autodesk
> > commercial FDO).
> > If you delete the connection, and recreate it...you will find the new
> > tables in the list.
> > May be when a connection is created, the server creates a file containing
> > the database catalogue structure.
> View this message in context: http://www.nabble.com/feature-class-in-mapguide-studio-tf4935604s16610.html#a14147147
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
