[mapguide-users] Overlapping labels for points
Christy Nieman
cnieman at dmsolutions.ca
Tue Dec 4 11:15:06 EST 2007
It works, thanks. This seems to be a bug to me. I checked and didn't
see any bug reports relating to this - did I miss something? If not
I'll submit a bug.
Traian Stanev wrote:
> And if that fixes it, make the symbol 1 pixel and transparent so that
> it is not visible. J
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andrew
> DeMerchant
> *Sent:* Tuesday, December 04, 2007 9:34 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] Overlapping labels for points
> Hmm. Maybe something to try would be turning on symbols....to see if
> it's a bug that only occurs when you've got no symbols showing, but do
> have labels.
> Andrew
> Christy Nieman wrote:
> Assuming that Studio is reporting correctly, "Labels are fixed (not
> dynamic)" and "Allow other labels to obscure feature symbols on this
> layer" are not checked. In the XML files AllowOverpost is false. I'm
> not certain, but I believe the problem only happens when there are no
> symbols being displayed with the labels (i.e. I have it set so that
> when at large scales, there are no symbols drawn, just the city name
> labels).
> Christy
> Andrew DeMerchant wrote:
> Am I right in saying that your layers labels are not 'dynamic'? In MG
> Studio, in the same area that you edit your label settings, you can
> specify some additional settings....If you set them to be dynamic,
> they shouldn't overlap - but that will cause some to not show up,
> until you zoom in.
> Andrew
> Hello all,
> I've been working with MapGuide OS for some time now and I've noticed
> a problem with labels for points overlapping. I have attached an
> image with an example of the problem I'm having. The Layers were
> created with MG Studio, and I'm using MGOS 1.2.
> While the attached image shows labels from several layers (same SDF
> feature source, different attribute filters), I have confirmed that
> the problem also happens with labels in the same layer. Has anyone
> seen this before? Is there a solution?
> Thanks,
> Christy
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
