[mapguide-users] Re: [OSGeo-Discuss] Tomcat error on Release 2.0.0
Beta 1
Robert Bray
rbray at robertbray.net
Thu Dec 6 01:29:56 EST 2007
Eric, this should be posted on the mapguide-users at osgeo.org list.
----- Original Message -----
To: discuss at lists.osgeo.org
Sent: Wednesday, December 05, 2007 12:34 AM
Subject: [OSGeo-Discuss] Tomcat error on Release 2.0.0 Beta 1
I successfully installed both MgServer and MgWebServerExtensions setup 2.0.0 Beta 1, but when I run the Tomcat using 'startup.bat' I got this error message from the log file:
Dec 5, 2007 2:44:45 PM org.apache.tomcat.util.digester.Digester startElement
SEVERE: Begin event threw exception
java.lang.ClassNotFoundException: org.apache.catalina.storeconfig.StoreConfigLifecycleListener
at java.net.URLClassLoader$1.run (Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClass (Unknown Source)
at org.apache.tomcat.util.digester.ObjectCreateRule.begin(ObjectCreateRule.java:205)
at org.apache.tomcat.util.digester.Rule.begin(Rule.java:153)
at org.apache.tomcat.util.digester.Digester.startElement (Digester.java:1276)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocumentParser.emptyElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch (Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse (Unknown Source)
at org.apache.tomcat.util.digester.Digester.parse(Digester.java:1562)
at org.apache.catalina.startup.Catalina.load(Catalina.java:504)
at org.apache.catalina.startup.Catalina.load(Catalina.java :538)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.apache.catalina.startup.Bootstrap.load(Bootstrap.java:260)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:412)
Dec 5, 2007 2:44:45 PM org.apache.catalina.startup.Catalina load
WARNING: Catalina.start using conf/server.xml:
at org.apache.tomcat.util.digester.Digester.createSAXException (Digester.java:2726)
at org.apache.tomcat.util.digester.Digester.createSAXException(Digester.java:2752)
at org.apache.tomcat.util.digester.Digester.startElement(Digester.java:1279)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement (Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement (Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument (Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse (Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at org.apache.catalina.startup.Catalina.load (Catalina.java:504)
at org.apache.catalina.startup.Catalina.load(Catalina.java:538)
at org.apache.catalina.startup.Bootstrap.main (Bootstrap.java:412)
at java.net.URLClassLoader$1.run(Unknown Source)
at org.apache.tomcat.util.digester.Rule.begin(Rule.java :153)
at org.apache.tomcat.util.digester.Digester.startElement(Digester.java:1276)
at com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocumentParser.emptyElement (Unknown Source)
at org.apache.catalina.startup.Catalina.start(Catalina.java :558)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:288)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413)
at org.apache.catalina.startup.Catalina.start(Catalina.java:558)
at org.apache.catalina.startup.Bootstrap.main (Bootstrap.java:413)
Dec 5, 2007 2:44:45 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 0 ms
I guess their is something to be a missing/damaged library file that is preventing the "Digester" - which reads the XML formatted configuration files - from running.
Thus anyone from this forum have an idea/links/documentation on how to solve this problem?
Thanks and regards,
Eric
Discuss mailing list
Discuss at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/discuss
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071205/28841f23/attachment.html
